Ih252hpb & if251hpbufn12 monitors
    When I turn on either monitor it comes on for a short while and then the screen goes black. I opened one of the monitors up and it had no bulging or leaking caps. I also examined the MB and there is no kind of distortion on it so I really do not know what is causing the issue but both monitors do the exact same thing. When I turn them on they both go to a black screen after a few minutes and once they are warmed up they go to a black screen in mere seconds. I did a little reading and I am thinking that it might possibly be one of the lamps in the monitors that has gone bad but I am not sure. If it is a lamp then how do I check them or where are they located in the monitors. Where can I find a schematic for these 2 monitors? Like I said I already took 1 apart and it is fairly simple. I never looked for the lamps at that time as I was just checking the caps and MB. Sure could use some helpful input to save these 2 25 inch monitors. Thank you very much
    Re: Ih252hpb & if251hpbufn12 monitors
    Any video on YouTube will do.
    I found this how to find what lamp its broken
    http://www.youtube.com/watch?v=eORAoaWpqao
      Ok that's cool but are the lamps really easy to find inside the monitor or what? I already looked at a thread here on the site on how to determine if the lamp is bad or not and it is kinda like when a light bulb burns out and gets black but what about the location of them in the monitors are they all located in about the same place or are all monitors different. Thanks for your help
