Samsung Syncmaster 943nw display shows a very very dark image
  • d0rkza
    • Dec 2013
    • Slovenija
    Hello! I'm triing to repair my lcd display (syncmaster 943nw).
    Problem:
    The display shows a very very dark picture (if you shine in it with a flash light you can see it). It does not make any sounds and it doesn't smell.
    Image:
  • Rtech
    • Jul 2010
    • 1095
    Re: Samsung Syncmaster 943nw display shows a very very dark image
    Follow the 2 seconds to Black Sticky.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Pic is not really clear enough for troubleshooting.
      First test resistance of secondary coils in the two big inverter transformers.
      Probably has two pins on one end, 6 on the other. Set meter on ohms 2000
      no power to board.
      See 2 seconds to black guide - sticky at front of this forum.
      Edit hah Rtech got in first
        09-07-2024, 05:50 AM
      • rattlesnake
        Samsung SyncMaster 955DF dim image fix
        by rattlesnake
        This display looks a bit dim but the image is otherwise fine. I already set the contrast to 100 and the brightness to 50 (more than that is counterproductive, it becomes hazy).
        To enable extra tuning, I have to enable the "Highlight Zone" function and stretch it to full screen. That way it looks really bright/intense and really good! I wish I could set it permanently like this, but as soon as you change the display mode/resolution or you turn the monitor off, you lose the "Highlight zone" config and you have to manuallly activate it again. Also, the manual says...
        08-12-2023, 07:03 PM
      • shlomim412
        samsung ua55es6800 - no image
        by shlomim412
        hi
        having problem with samsung ua55es6800
        tv had backlight on, sound working - responds to the remote control but no image.
        check tcon board - had 12v in but no other voltages present.
        when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
        when leaving only left side connected - again no voltages and no image.
        put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
        kept trying to block less pins on the left ribbon cable...
        05-15-2024, 05:00 AM
      • soopacrucial
        Samsung Syncmaster 740BF repair
        by soopacrucial
        Hi folks,
        I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
        Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
        10-29-2024, 02:40 PM
        09-06-2024, 11:40 PM
