Dell 2405FPW
  • Misterkeeks
    • Nov 2013
    • 74
    • America
    Dell 2405FPW
    I have a broken Dell 2405FPW. There is no sign of a backlight, an image with no backlight, and the lights on the front (power LED) do not illuminate. When plugged in there is a high pitched whine from the power supply. The caps are Elite and Lelon, but don't show any physical issue to me. I tried to measure the voltages that it gave to the logic board and the backlight board.
    to Logic Board
    Black: 0
    ?: 0
    Red: 20
    Orange: 0
    Yellow: 0
    Green: ~7-7.5
    to Backlight board
    Black: 0
    Brown: 0
    Red: 23-25
    Orange: 23-25
    Yellow: 0
    Green: 0
    Blue: 0
    If any of those zeroes seem strange, I can remeasure. It's possible that I didn't quite make contact with the wire.
    The capacitors on the power supply are as follows:
    450v 120uf PW(M) Elite
    6x 35v 470uf EL(M) Elite
    2x 35v 47uf Lelon RGA A523(M)
    1x 100v 1uf Lelon RGA A523(M)
    1x 35v 220uf Lelon RGA A523(M)
  • Misterkeeks
    • Nov 2013
    • 74
    • America
    Re: Dell 2405FPW
    Anyone?
    • selldoor
      Slow Learner
      • 7870
      Re: Dell 2405FPW
      Ill set the ball rolling- with a question. Are F701 and F702 fuses or
      ferrite - either way test them as fuses. No power to board.
      meter on ohms200 probe to each end.
      Did you have the boards all connected when testing at socket
      • Misterkeeks
        • Nov 2013
        • 74
        • America
        Re: Dell 2405FPW
        My multimeter(s') resistance function does not work, so I'll have to grab a new one, or get rid of the 30 years of battery acid off of the old multimeter.
        When I was testing at the socket, I did not have all the boards connected. When I was testing the board leading to the logic board, I unplugged the cable, and measured each wire. I did have the backlight board connected when measuring the logic board cable, and vice versa. I didn't try an measure while the cable was plugged in, as I would have to have it partway into the socket and I was worried that I would short it out. However, I could try to do that.
          Re: Dell 2405FPW
          This may help:
          https://www.badcaps.net/forum/showth...FPW#post359898
          https://www.badcaps.net/forum/showth...t=Dell+2405FPW
          But your meter voltage reading does not seem right.
          • selldoor
            Slow Learner
            • 7870
            Re: Dell 2405FPW
            Ah yes its coming back to me now - knew I had seen those fuses before
            here is another thread
            https://www.badcaps.net/forum/showth...d=1#post323405
            But nothing more we can do until you get a working meter.
            Please dont ask which one to get or we will have another
            stream from Kiriakos
            also see here
            https://www.badcaps.net/forum/showpo...9&postcount=21
            • Misterkeeks
              • Nov 2013
              • 74
              • America
              Re: Dell 2405FPW
              Got an ancient meter working. F702 has no resistance, F701 has infinite resistance.
              • selldoor
                Slow Learner
                • 7870
                Re: Dell 2405FPW
                ok - it will probably say on them or on the board what value they should be.
                I would order a few or a fuse holder that will take loose fuses.
                • Misterkeeks
                  • Nov 2013
                  • 74
                  • America
                  Re: Dell 2405FPW
                  OK, bunch of questions.
                  F701, the faulty fuse, has the identifications printed face down. I have looked around this site and the only specification that I can find is that it is a 5 amp fuse. What do you think the voltage would be. I'll have a soldering iron soon so I could just desolder it and order it, but if you have an idea, I could order now.
                  I ordered a bunch of capacitors a while back for this, but I believe that they might have too high of an ESR to be useful. The caps are as follows.
                  120uf 450v Nichicon PZ Series
                  470uf 35v Nichicon NHG Series
                  47uf 35v Nichicon NHG Series
                  1uf 100v Nichicon PZ Series
                  220uf 35v Nichicon VZ Series
                  • Misterkeeks
                    • Nov 2013
                    • 74
                    • America
                    Re: Dell 2405FPW
                    The 450v 120uf would replace a PW(M) Elite Capacitor
                    The 35v 470uf would replace EL(M) Elites
                    The rest would all replace Lelon RGA A523(M) capacitors
                    • selldoor
                      Slow Learner
                      • 7870
                      Re: Dell 2405FPW
                      Almost any nichicon is probably better than Lelon or Elite but if you can stick to panasonic FR FM or FC (from best to less best) for the small caps - the
                      big cap is ok.
                      Nichicon should probably be HN or HZ
                      Incidently the links you gave to digikey are not for the caps described??
                      • Misterkeeks
                        • Nov 2013
                        • 74
                        • America
                        Re: Dell 2405FPW
                        big cap is ok.
                        OK. I will either return or not use the other caps.
                        You are correct.
                        I'll get that sorted out.
                        470uf 35v Panasonic NHG Series
                        47uf 35v Panasonic NHG Series
                          HP Elite Elite Slice Elite i5-6500T Specification for Upgrade or Repair
                          This specification for the HP Elite Elite Slice can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice boardview and Elite Elite Slice schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 03:44 PM
                          HP Elite Elite Slice Elite i3-6100T Specification for Upgrade or Repair
                          HP Elite Elite 7100 Microtower PC Elite 7100 i3-530 Specification for Upgrade or Repair
                          This specification for the HP Elite Elite 7100 Microtower PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7100 Microtower PC boardview and Elite Elite 7100 Microtower PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                          HP Elite Elite Slice (ENERGY STAR) Elite i5-6500T Specification for Upgrade or Repair
                          This specification for the HP Elite Elite Slice (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice (ENERGY STAR) boardview and Elite Elite Slice (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
