Dell 2407WFp, strange problems
  • elagil
    • Oct 2013
    • 44
    I am having some problems with my 2407. It sometimes switched off entirely so I now decided to replace all caps on the power supply and the inverter board. I did not actually pay attention to choosing low ESR models or anything, I just matched capacity and voltage rating.
    So I ended up with some "YAEGO SY" for the 470uF/35V: http://www.google.com/url?sa=t&rct=j...57604443,d.Yms
    and "YAEGO SE-K" for all of the rest:
    while the former are low esr models, the others are not.
    When replacing one of the capacitors I ripped off a trace which I replaced with a thin isolated wire. that should not be an issue.
    Nevertheless, most of the times when switching on the monitor, it now shows wild colors and stripes until I repower it or wait some seconds. As a matter of fact, this seems to depend on the angle, the monitor is lying at, which I find rather strange.
    It seems that some circuit that delivers the image to the panel does not power up! When working normally, some whirring sound comes out of the circuit below the shielding can which accepts the lvds cable. When I get artifacts and lines and such, the whirring is gone and the monitor is silent.
    Can this be caused by choosing those SE-K type Capacitors, which are of too low quality? I did not have that problem before. Still, the backlight is working perfectly fine.
    Thank you in advance,
    Adrian
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Dell 2407WFp, strange problems
    Check your soldering with a magnifying glass and disconnect clean and reconnect ALL cables. Fact that it changes with different angles suggests a physical problem.
    Then consider upgrading your caps
    • elagil
      • Oct 2013
      • 44
      I swapped the 1uF cap with the one that came installed and the problems are gone. Might be that this is because of the improved solder joint due to the second attempt at soldering.
      However I am going to leave it that way. I guess that the 1uF Cap has not failed anyway.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Caimano
        Problems extracting from Dell Bios Update.Inspiron 3793
        by Caimano
        I am trying to repair a Dell Inspiron 3793 which has problems with start up, no battery charging and fan not running. I believe the Bios (probably the EC Region) is corrupted.
        The board is FDI45-LAJ091P REV 1.0 A00
        Processor i7 1065G7 with GPU
        This MB has 2 Bios Chips (one 8MB and one 16MB chip).
        I am trying to reload a new Bios with clean ME region, new main region and new EC region.
        I attach the dumps of the 2 chips.
        I successfully used ME analyzer to identify ME, PCH and PMC versions and used Flash Image Tool to install ME, PCH and PMC cleaned regions....
        05-04-2022, 11:19 AM
      • stakrzysiu
        Dell Vostro 15 5501 BIOS Problems
        by stakrzysiu
        i have here a Dell Vostro 15 5501
        REG Model: P102F
        SN: 1WD5103
        there is a problem that it shows screen after 1 min.
        Is this caused by me?
        Can someone clean me for me? Then i will try.
        Thank you very much
        Best regards...
        01-25-2025, 05:36 AM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
      • diamon
        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
        by diamon
        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
        Pictures of these boards:
        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
        Dell...
        02-28-2024, 12:51 PM
