LG W2053TQ 2 seconds to black
  • Maxmad
    • Jul 2013
    • 58
    • Greece
    This monitor faces 2 seconds to black problem.
    Image is still visible when direct light hit the screen, so the logic board seems to be ok for now.
    --I have already checked the transformer. Both inputs and outputs ohms are ok. However I replaced it with a spare one. Problem persists.
    --CCFL are also good. I checked all 4 of them one by one, and all together with another inverter. Everything fine.
    --2 dual mode Mosfets are ok. Both measured and checked outside of the circuit.
    --Capacitors are all also checked. One of them was faulty and replaced. All other are good both with their capacity and ESR value.
    I focused on IC DT8211 Light Inverter drive.
    Pulse at pin 7 is triangle and correct. It is on all the time when monitor is on.
    Pulse at pin 8, 16 and 17 seems ok but is off when monitor turns black. Seems as normal behavior because if the pulse at pins 16-17 stays alive then the HV will work and so does the CCFL.
    Some voltage at pins 1,6,18 is ok too.
    I tried to isolate the feedback section of the IC. So i desoldered pins 10,11 as it seems at the photos. Stll the same 2 seconds to black problem.
    Is there any way to check if the IC is wrong? I don't know what else to check... I only missed the SMD resistors and capasitors (SMD diodes are checked OK)...
    Maybe there is something wrong with other power supply signals or probably the logic board? for example signals like ADIM, BDIM... any way to test them?
    Any help will much be appreciated. This schematic seems to be very close to W2053TQ as for the inverter part.(page 23)
    Re: LG W2053TQ 2 seconds to black
    Can you locate the BL_ON (or INVR_ON) pin to see if it still present when the screen black out? The 4 blue high voltage ballast caps checked out fine with no resistance leakage? Pin 2 is the ENABLE pin which is the BL_ON.
    BTW, if you look at page 6, pin 9 is the protection pin, if that pin is allow to rise above 3V, the comparator output will go high and shut down the out put drive circuit, if some thing is wrong in the first 3 seconds the Prot will activate, the cap on the PROT pin set the time (see page 9). You can ground out pin 9 to see if it will stay on but you will not have any protection.
    Just about every inverter circuit has 3-second detection so something bad happen in the 3 seconds window, it will shutdown.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4367
      • Italy - Milan
      ballast caps, the blue ones?
      • Maxmad
        • Jul 2013
        • 58
        • Greece
        thank you all for your help.
        I am back after almost a month waiting for a power supply board replacement.
        After many troubleshooting I decided to replace the whole board since I found nothing wrong with the original.
        Replace with a brand new board and faced the same problem: 2-sec to black.
        I rechecked the CCFLs and found a very unusual situation:
        According to the picture this is the right connection between male and female connectors of CCFLs. 2sec occurs with this connection.
        Leaving connector D with the original CCFL 4 and using a spare CCFL to connector C makes the problem disappeared.
        Same if leaving connector C with the original CCFL 3 and using a spare CCFL to connector D makes the problem disappeared again!
        So seams that only if both 3 and 4 CCFLs are connected at the same time causes the problem.
        Rearranging the CCFLs to the connector as below (pairs twisting):
        A--->3
        B--->4
        C--->1
        D--->2
        Still 2 sec to black problem...
        But after a twist between 3-4 :
        A--->4
        B--->3
        C--->1
        D--->2
        Problem disappeared! I checked both male and female connectors for problems and found nothing.
        2sec to black problem disappears only with the above combination without changing the original CCFLs...
        Sounds very strange to me... Probably both 3-4 CCFLs are faulty, but why only this combination works?
        • Maxmad
          • Jul 2013
          • 58
          • Greece
          just to close the thread:
          the problem was a defected ccfl lamp.
          the system was able to start only under certain ground circumstances.
          so that's way sometimes everything worked fine and sometimes not.
          hope this helps on a similar situation.
          • ChIck3n
            Dell u2311h 20000 seconds to black issue
            by ChIck3n
            So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
            09-09-2024, 11:44 AM
            MSI Gaming Pulse GL66 12UGK-470CA Notebook GL Specification for Upgrade or Repair
            This specification for the MSI Gaming Pulse GL66 12UGK-470CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pulse GL66 12UGK-470CA boardview and Pulse GL66 12UGK-470CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 06:40 AM
            MSI Gaming PULSE GL76 12UEOK-692FR Notebook GL Specification for Upgrade or Repair
            This specification for the MSI Gaming PULSE GL76 12UEOK-692FR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PULSE GL76 12UEOK-692FR boardview and PULSE GL76 12UEOK-692FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 06:38 AM
            MSI Gaming PULSE GL66 12UGSZOK-1096 Notebook GL Specification for Upgrade or Repair
            This specification for the MSI Gaming PULSE GL66 12UGSZOK-1096 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PULSE GL66 12UGSZOK-1096 boardview and PULSE GL66 12UGSZOK-1096 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            MSI Gaming Pulse GL76 12UEK-426XPT Notebook GL Specification for Upgrade or Repair
            This specification for the MSI Gaming Pulse GL76 12UEK-426XPT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pulse GL76 12UEK-426XPT boardview and Pulse GL76 12UEK-426XPT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 06:21 AM
