Cap volts?
  • ivtec
    • Dec 2008
    • 1967
    Cap volts?
    Hi guys i have here a Lcd pc monitor and it has a 100farads 450v in the power sup, that is dry can i use 200v instead of the 450?
  • Majestyk
    • Nov 2013
    • 96
    Re: Cap volts?
    Don't!
    You can use 450V DC or more.
    The capacity is probably uF not F - the unit would have a remarkable size otherwise.
    • ivtec
      • Dec 2008
      • 1967
      Re: Cap volts?
      Originally posted by Majestyk
      Don't!
      Thanks,true is 100uf450v, i have many caps on my scrap but none with that volts.
      • mariushm
        • May 2011
        • 3799
        Re: Cap volts?
        If the monitor doesn't have active power factor correction, the AC voltage gets rectified so you will have 120v x 1.414 = 170 volts. You may get more than 120v at the socket, you may get less, so the rectified voltage may get close to 180-185v. So using a capacitor rated for 200v would maybe work but it's awfully close to 200v, and I wouldn't recommend it.
        As I said, IF there's no active pfc. In this case, it's possible they may have used a 450v rated capacitor so that they won't change the power supply in countries with voltages that can be 240v +/- a few percents. In those countries you get 240x1.414 = 340+ volts, so you need at least a 420v rated capacitor.
        BUT, if the monitor uses active pfc, the active pfc circuitry will boost the rectified voltage to some value, which normally is about 380v-400v or maybe even more. So you'd need to use a 450v rated capacitor.
        Most monitors will work at high voltage, it's just hard to sell monitors without due to regulations for efficiency and low standby power and so on.
        • ivtec
          • Dec 2008
          • 1967
          Re: Cap volts?
          Thanks Bro for that Very good Explanation,i'm going to lieve this lcd repair alone, i have a couple more monitors , besides who ever threw it out cut both the video cord and power cord, not worth it the trouble,maybe i can salvage the panel lcd,i have a lenovo lcd monitor same size panel lcd
          • lexwalker
            • Feb 2011
            • 307
            • Malaysia
            Re: Cap volts?
            Sometimes I've used 400V ones, when I don't have any spares left. But only for monitors that do not have PFC. Otherwise I will stick to 450V...
            • Majestyk
              • Nov 2013
              • 96
              Re: Cap volts?
              I would recommend to stay on the safe side (450Vor more). You never know - maybe some day the TV is taken to any country (for example in south america) where there is a mains voltage of 220V. Since there´s probably a rating of 100-240V printed on the Label someone plugs it in and -
              "boooom"
              • lexwalker
                • Feb 2011
                • 307
                • Malaysia
                Re: Cap volts?
                "boooom"
                My country uses 230VAC for the mains. Already used 400V capacitors for quite a number of repairs already, and none came back for second round of repairs...
                • Majestyk
                  • Nov 2013
                  • 96
                  Re: Cap volts?
                  And none of them ever will - I´m sure.
                  I referred to the possibility to use 200V as mentioned in post #1 and #4
                  • lexwalker
                    • Feb 2011
                    • 307
                    • Malaysia
                    Re: Cap volts?
                    Majority of LCD monitor power supplies are universal, can accept 110VAC to 240VAC mains input. Thus usually 400V would be the safe minimum, in most cases. Although I would not recommend 200V though...
                    • ivtec
                      • Dec 2008
                      • 1967
                      Re: Cap volts?
                      Thanks guys: If i understand i can use a 200V 100uf cap as long i use 120v power?
                      • mariushm
                        • May 2011
                        • 3799
                        Re: Cap volts?
                        Short answer is that IT DEPENDS. Most often you can't.
                        It depends on how the power supply is built.
                        If the power supply has a Active PFC circuit, then no, the voltage will be boosted by this Active PFC circuit to about 380-400 volts so you need a capacitor rated for at least that voltage, therefore 450v rated capacitors are used.
                        The majority of power supplies will be like this.
                        Just order some 450v rated capacitors from Digikey or Mouser or Newark and forget about shortcuts.
                        Most monitor power supplies use capacitors in the range of 100-150uF - you can generally go a bit more or a bit less in capacitance (ex. use a 82 uF instead of 100uF, or 120uF instead of 150uF, or use 120uF instead of 100uF) so you could just get a few capacitor sizes and install the closest one you have when needed.
                        • MisterAIL
                          PS5 digital / No Power / No Beep / Good power supply
                          by MisterAIL
                          Brought a non functionnal PS5. Apparently only a bad PSU...
                          No beep, nothing.
                          After some tests i found this :
                          - PSU is fine (12 volts stable)
                          - 12 volts line is shorted
                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                          - By the way, nothing change. No signal, no power, no beep.
                          Mesuring all rails with my workbench psu (12 volts input)
                          - 0.00 amp drawing
                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                          03-12-2024, 03:24 PM
                        • BTubbs200
                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                          by BTubbs200
                          Dell Latitude 5420 P137G
                          Board: LA-K491P REV A01
                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                          Board seems to have no shorts, all power rails are fine and show high resistance.
                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                          01-24-2025, 08:15 PM
                          MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
                          by sam_sam_sam
                          I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
                          I open it up to find non brands name capacitors in it
                          I am not sure how this switching power supply is set up
                          Could someone please explain how this power supply works
                          Here is the capacitor ESR results
                          (1) 47uf@50 volts 0.46
                          (2) 47uf@50 volts 0.45
                          New 47uf@50 volts 0.35
                          (1) 100uf@25 volts 0.34
                          (2) 100uf@25 volts 0.35
                          New 120uf@50 volts 0.08
                          (1) 220@25 volts 0.13...
                          10-21-2018, 10:02 AM
                          I am looking for a transformer secondary of 60 volts @ 30 amp
                          by sam_sam_sam
                          The primary voltage is 480 single phase the second voltage needed is 60 volts
                          Now it could be 30 volts 0 volts 30 volts preferred
                          Or it could be 60 volts 0 volts 60 volts and just use one side of
                          Output amp need to be at least 30
                          Dose anyone know where I can find one
                          This is what is the device I am working on
                          The problem with this one is that it is over heating and smelling like it is over heating
                          When it has a load on it...
                          07-01-2020, 08:14 PM
                        • Superbee_dad
                          Sharp 80” long short flash backlight error - Help
                          by Superbee_dad
                          Hello Sharp TV experts
                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                          01-24-2025, 11:51 PM
