Cap volts?
  • ivtec
    • Dec 2008
    • 1967
    Cap volts?
    Hi guys i have here a Lcd pc monitor and it has a 100farads 450v in the power sup, that is dry can i use 200v instead of the 450?
  • Majestyk
    • Nov 2013
    • 96
    Re: Cap volts?
    Don't!
    You can use 450V DC or more.
    The capacity is probably uF not F - the unit would have a remarkable size otherwise.
    • ivtec
      • Dec 2008
      • 1967
      Re: Cap volts?
      Originally posted by Majestyk
      Don't!
      Thanks,true is 100uf450v, i have many caps on my scrap but none with that volts.
      • mariushm
        • May 2011
        • 3799
        Re: Cap volts?
        If the monitor doesn't have active power factor correction, the AC voltage gets rectified so you will have 120v x 1.414 = 170 volts. You may get more than 120v at the socket, you may get less, so the rectified voltage may get close to 180-185v. So using a capacitor rated for 200v would maybe work but it's awfully close to 200v, and I wouldn't recommend it.
        As I said, IF there's no active pfc. In this case, it's possible they may have used a 450v rated capacitor so that they won't change the power supply in countries with voltages that can be 240v +/- a few percents. In those countries you get 240x1.414 = 340+ volts, so you need at least a 420v rated capacitor.
        BUT, if the monitor uses active pfc, the active pfc circuitry will boost the rectified voltage to some value, which normally is about 380v-400v or maybe even more. So you'd need to use a 450v rated capacitor.
        Most monitors will work at high voltage, it's just hard to sell monitors without due to regulations for efficiency and low standby power and so on.
        • ivtec
          • Dec 2008
          • 1967
          Re: Cap volts?
          Thanks Bro for that Very good Explanation,i'm going to lieve this lcd repair alone, i have a couple more monitors , besides who ever threw it out cut both the video cord and power cord, not worth it the trouble,maybe i can salvage the panel lcd,i have a lenovo lcd monitor same size panel lcd
          • lexwalker
            • Feb 2011
            • 307
            • Malaysia
            Re: Cap volts?
            Sometimes I've used 400V ones, when I don't have any spares left. But only for monitors that do not have PFC. Otherwise I will stick to 450V...
            • Majestyk
              • Nov 2013
              • 96
              Re: Cap volts?
              I would recommend to stay on the safe side (450Vor more). You never know - maybe some day the TV is taken to any country (for example in south america) where there is a mains voltage of 220V. Since there´s probably a rating of 100-240V printed on the Label someone plugs it in and -
              "boooom"
              • lexwalker
                • Feb 2011
                • 307
                • Malaysia
                Re: Cap volts?
                "boooom"
                My country uses 230VAC for the mains. Already used 400V capacitors for quite a number of repairs already, and none came back for second round of repairs...
                • Majestyk
                  • Nov 2013
                  • 96
                  Re: Cap volts?
                  And none of them ever will - I´m sure.
                  I referred to the possibility to use 200V as mentioned in post #1 and #4
                  • lexwalker
                    • Feb 2011
                    • 307
                    • Malaysia
                    Re: Cap volts?
                    Majority of LCD monitor power supplies are universal, can accept 110VAC to 240VAC mains input. Thus usually 400V would be the safe minimum, in most cases. Although I would not recommend 200V though...
                    • ivtec
                      • Dec 2008
                      • 1967
                      Re: Cap volts?
                      Thanks guys: If i understand i can use a 200V 100uf cap as long i use 120v power?
                      • mariushm
                        • May 2011
                        • 3799
                        Re: Cap volts?
                        Short answer is that IT DEPENDS. Most often you can't.
                        It depends on how the power supply is built.
                        If the power supply has a Active PFC circuit, then no, the voltage will be boosted by this Active PFC circuit to about 380-400 volts so you need a capacitor rated for at least that voltage, therefore 450v rated capacitors are used.
                        The majority of power supplies will be like this.
                        Just order some 450v rated capacitors from Digikey or Mouser or Newark and forget about shortcuts.
                        Most monitor power supplies use capacitors in the range of 100-150uF - you can generally go a bit more or a bit less in capacitance (ex. use a 82 uF instead of 100uF, or 120uF instead of 150uF, or use 120uF instead of 100uF) so you could just get a few capacitor sizes and install the closest one you have when needed.
                        • u666sa
                          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                          by u666sa
                          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                          Platform: ipa32 la-m024p rev 1b
                          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                          I found a short on the other side:
                          10-04-2025, 05:03 PM
                        • supermattch
                          HP 15dy-2021nr wont power on mystery volts
                          by supermattch
                          Hi everyone.
                          I am diagnosing my personal laptop, because it wont power on and no leds light up.
                          At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                          Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                          09-23-2025, 12:13 PM
                        • MisterAIL
                          PS5 digital / No Power / No Beep / Good power supply
                          by MisterAIL
                          Brought a non functionnal PS5. Apparently only a bad PSU...
                          No beep, nothing.
                          After some tests i found this :
                          - PSU is fine (12 volts stable)
                          - 12 volts line is shorted
                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                          - By the way, nothing change. No signal, no power, no beep.
                          Mesuring all rails with my workbench psu (12 volts input)
                          - 0.00 amp drawing
                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                          03-12-2024, 03:24 PM
                        • Mcfeetroy
                          Fishing bite alarm drains battery
                          by Mcfeetroy
                          Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                          08-01-2025, 03:52 AM
                        • BTubbs200
                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                          by BTubbs200
                          Dell Latitude 5420 P137G
                          Board: LA-K491P REV A01
                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                          Board seems to have no shorts, all power rails are fine and show high resistance.
                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                          01-24-2025, 08:15 PM
