MAG h2401c no signal
  • gasinmars
    • Apr 2013
    • 53
    • israel
    hi i have a stange problem about this lcd , when i turn the lcd on it told me first of all that it has " no signal" and then the power led Flickering , how could i solve this problem give me a solution , thanks alot , by the way iam using "VGA CABLE".
  • gasinmars
    • Apr 2013
    • 53
    • israel
    Re: MAG h2401c no signal
    pictures
    • gasinmars
      • Apr 2013
      • 53
      • israel
      can any one give me an advice
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • AstutePauciloquent
        Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
        by AstutePauciloquent
        Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
        I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
        11-23-2023, 11:02 PM
      • reessi
        ACER BM320 Monitor - Horizonal Flickering Lines After a While
        by reessi
        The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
        They are black on the right and gradually fade to nothing on the far left.
        They start either after 5 mins or up to 2 hours after so annoying for testing.
        They flicker continuously very fast! With a slight pause milli-second every second.
        Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
        I tested each half by removing the first the left flex from...
        06-03-2025, 09:58 AM
      • howardc64
        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
        by howardc64
        Failure Symptom
        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
        Where is the short?
        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
        05-27-2025, 02:56 PM
      • JayPoorJay
        Converting +/- 5v to a Usable Hz Signal
        by JayPoorJay
        Good morning.
        I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
        This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
        The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
        08-07-2022, 08:35 AM
