Samsung SyncMaster 2493HM - Damaged component power board
  • kiwitac
    • Sep 2013
    • Belgium
    A component in the power board of my LCD screen exploded and I have some troubles about finding information or specifications about the damaged part.
    The component looks like a cap, but also like a resistor with an inductor around it (sorry, I'm new to this).
    The part says CNA4.5x12-120R-5%, and is found here:
    Would anybody know something about this part or can suggest an alternative part?
    Thank you,
    kiwitac
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Samsung SyncMaster 2493HM - Damaged component power board
    Looks like a resistor, but I can't tell. Check the board designator and what letter it begins with.
    R = resistor
    C = capacitor
    L = inductor
    FB = ferrite bead
    D = diode
    Post some well-lit and well-focused, top and bottom side pictures of your board too. This will help us determine what value it may be based on what it is connected to. Please use the forum's "Manage Attachments" options when attaching your pictures.
    • popbriz
      • Sep 2010
      It's a 0.22ohm resistor
      • delaware74b
        • Apr 2009
        • 628
        Also, when repairing your board remove all of the tan-colored glue. It turns brown and gets conductive as it is exposed to heat. Good for
        Stupidity should be a crime, especially for drivers. I have NO patience for them.
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • ohren
          by ohren
          09-08-2023, 05:24 PM
        • C152Heavy
          by C152Heavy
          Summary for TL-DR readers:
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
          09-07-2024, 05:50 AM
