Dell SX2210T LCD Vertical Flicker
  • dallama
    • Sep 2013
    • usa
    Here are symptoms for my Dell SX2210T LCD monitor:
    Computer starts fine at first. After 10 minutes or so, it starts vertical flickering from left bottom (at least it seems rather strong on the left bottom side). After a while it subsides then starts again. Flickering is more apparent and annoying on dark background. Flickering does not go away during BIOS when restarted so video card should be fine.
    I reviewed a number of threads on flickering problem. As suggested, I looked at all the caps (10x 220uf 25V) on power board. Although they were all Lelon caps, visually all looked OK. Anyway, I replaced all (10 of them) with new Panasonic ones. After replacement, screen was fine for 30 minutes or so but flickering started again.
    Caps on logic board, where display outlets are located, also look ok. They were much smaller caps (maybe 10 uf 25v, I am not sure).
    I appreciate your feedback on this issue. I have been searching for the past few weeks but could not find any similar issue related this particular monitor.
  • dallama
    • Sep 2013
    • usa
    Re: Dell SX2210T LCD Vertical Flicker
    Here is a picture of the issue.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Shobos
      Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
      by Shobos
      Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
      So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
      NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
      Any help is welcome. Thanks !
      07-29-2025, 03:53 PM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
      Dell Thunderbolt Firmware
      by SMDFlea
      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
      The SKU is in brackets (****)
      EDIT: NVM65...
      01-26-2025, 06:22 AM
