Samsung S24A350H Backlight Problem
  • Schorsch87
    • Feb 2013
    • 55
    Hi Guys,
    i have a problem with my Samsung Display. The LED-Backlight doesn't work anymore. I can see the picture using a flashlight. At start-up the backlight lights up for a split second. The Mainboard has a connector for the LEDs. The connector has 6 pins. 1,2 named LED1 LED2, 3,4 named V_out and 5,6 named LED3 LED4.
    The LED named pins have stable voltage of about 4V. The other ones aren't very stable. It jumps from 13,92V to 36V and then pumps down to 13,92V.
    So, please help me.
    Regards
  • cmia
    • Aug 2013
    • 37
    • United Kingdom
    Re: Samsung S24A350H Backlight Problem
    Pictures of the board please / read the FAQ
    • Schorsch87
      • Feb 2013
      • 55
      The small connector leads to the LED backlight. Both pins in the middle have the pumping voltage. The other ones read the stable 4V.
      Regards
      • Schorsch87
        • Feb 2013
        • 55
        Hey, does anybody know something that would help me?
        • Schorsch87
          • Feb 2013
          • 55
          Come on guys :/
          • jetadm123
            • 2169
            The external power adapter provides a 12vdc output, correct? Odd that you're seeing a 36V spike at V_out. I would try the following: test the input voltage from the power adapter right at the input jack of the motherboard. If you still see the 36V spike, then there could something wrong with the power adapter itself. I believe the LED pins should be driven at 5VDC, but you're reading 4V, which could indicate a possible short or a bad voltage regulator. As a final note, please verify your meter is operating correctly. Measure a 9V battery to verify it's reading voltage correctly. If not, try replacing the meter's battery.
              Please post the P/N of the LED DRIVER IC, it looks like it uses 4 strings of LED.
              • Schorsch87
                • Feb 2013
                • 55
                I tested the power supply right at the input jack on the mainboard. The voltage is stable at 14V.
                Here's the partnumber: BD9264EFV 149 H36
                Regards
                • Schorsch87
                  • Feb 2013
                  • 55
                  Another ideas?
                    So far I have no luck finding the data sheet for this IC (BD9264EFV) yet.
                    • JoeyJoe
                      • Sep 2012
                      • 76
                      • United Kingdom
                      Is the power adapter supposed to be 14v? What is the rating on the label?
                      • Schorsch87
                        • Feb 2013
                        • 55
                        It's the right voltage. 14V and 2.14A is the rating.
                        I have no idea what the problem might be. And I don't find an Service Manual with test points or something like that. I don't know the backlight works. If I would know I could test it with an external power supply.
                        Regards
                        • jetadm123
                          • 2169
                          One suggestion: around the area of the LED driver that budm circled, try looking for a fuse marked something like FXXX (where XXX is some number). If there is a fuse check it for continuity.
                          Also, please provide a more focused photo of the circled area where we can actually read the numbers stamped on the board itself.
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            The BD prefix leads me to believe that the LED driver IC is made by Rohm. BUT, I can't find this chip listed on their website
                            It might have been a custom order chip, maybe you can contact Rohm to see if they made the BD9264. They do have a chip listed on their site as BD9267, which is an LED driver. OR, perhaps the BD9264 is an obsolete part. You'd think they would still have the datasheet for the obsolete part though...
                            Muh-soggy-knee
                            • Schorsch87
                              • Feb 2013
                              • 55
                              Here I have a more focused picture. Can't find any fuse. I thought about a defective cap, maybe a SMD, but I don't own the right testing device. Just a multimeter.
                              Thanks for the advice ben7.
                              Regards
                              • jetadm123
                                • 2169
                                This is a tough one since there's no datasheet for the BD9264. Difficult to know which pin does what. I only thing I can suggest is to check the power mosfet right above the inductor, L101, for a short. The mosfet is stamped 9997GH. Look up the data sheet for a AO9997GH. With power off and your meter set to resistance, place your probes across:
                                Gate-->Source
                                Source-->Drain
                                Drain-->Gate
                                • Schorsch87
                                  • Feb 2013
                                  • 55
                                  I had already checked the mosfet. This is what I do first. The power mosfet is in a good condition and shows no shortcut.
                                  • flocko
                                    • Nov 2012
                                    • 1121
                                    Hi can you check the voltage on the six pin plug again but using the two center pins3/4 as the common as they look to be joined see what do you get pin1 and pin3/4= p2 and p3/4= p5 and p3/4= p6 and p3/4=
                                    • Schorsch87
                                      • Feb 2013
                                      • 55
                                      I do not know what has happened, but the Display is working again. I wanted to measure the voltage over pin1-pin3/4 and after placing the measuring tips the backlight started working?! I'm a little bit confused
                                      Now I have to monitor if it is working on every condition.
                                      Regards
                                      • flocko
                                        • Nov 2012
                                        • 1121
                                        It sounds to me as if you could a cold solder connection on the two common pins number 3/4? glad it working for you Regards flocko
                                        • fanaticgames
                                          Samsung UE32D4010 Backlight problem, led ok
                                          by fanaticgames
                                          hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                          02-22-2023, 09:46 AM
                                          09-07-2024, 05:50 AM
                                        • sandinemail@hotmail.com
                                          Samsung BN44-00284A Backlight problem
                                          by sandinemail@hotmail.com
                                          Samsung BN44-00284A in a Samsung LE40B755 TV bought 2009.
                                          In November 2020 the TV didnยดt turn on only flashing red diod on front off TV.
                                          I then opened up the TV and found bulged capacitors on the inverter/powerboard.
                                          I changed all capacitors except the main two 450V 100uf capacitors.
                                          The TV has worked pefectly since.
                                          But this week it started to turn off the backlight. Audio on TV still works.
                                          Sometimes it turn off the backlight after 10 seconds but sometimes it works for hours.
                                          Any suggestions on what might...
                                          02-15-2023, 05:10 AM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                        • Bloopeta
                                          Samsung UE55H8000 Backlight Power Problem
                                          by Bloopeta
                                          Have a Samsung UE558000, which I thought was just going to be a straightforward backlight replacement, as the screen was dark in the middle.
                                          After stripping it down, I noticed it was exactly the same lights out on both sides (see pic)
                                          I tested the strips with LED tester, and no bulbs were out, so I tested the voltage going to the strips, both at the board side, and at the strip.
                                          On Blue, there is 30.5v on pin 3 and 9, but nothing on the others.
                                          Same situation on White, 30.5v pin 2 and pin 8
                                          All caps look ok, anyone any idea?...
                                          01-30-2023, 01:34 PM
