Samsung 2253BW - 2 Sec to Black issue
+ More Options
Posts
  • AdamJ
    • Aug 2013
    • 8
    I recently purchased 2 faulty Samsung 2253BW monitor with the aim of fixing them both seeing as i successfully repaired my Samsung 19" TV. I've successfully repaired one of the 2253BW already by replacing the fuse (F301) and bad caps (C301 & C302) but i'm having trouble with the other one.
    So far i've replaced:
    C301 (820uf 25v)
    C302 (820uf 25v)
    C108 (820uf 25v)
    C112 (820uf 25v)
    C115 (1000uf 16v)
    C116 (1000uf 16v)
    C119 (330uf 10v)
    C107 (47uf 50v)
    F301 (125v 4a)
    But still the screen comes on for 2 seconds and then off. Also, there is a high pitched noise which changes when the screen is switched off and on. Seems to be coming from around LF101 (near the power plug). Not sure if this is a red herring tho.
    I know the screen panel is good as I've used a good power board on it and it displays fine.
    Picture of the power board below:
    Any suggestions welcomed.
    Thanks for you replies in advanced.
    Cheers
    Adam
    Re: Samsung 2253BW - 2 Sec to Black issue
    There are two SMD 8-PIN MOSFETs which drives the HV Inverter transformer, that section got very hot as you can see the board has burnt mark, you need to check them. Can you read the number as printed on top of the MOSFETs?
    • AdamJ
      • Aug 2013
      • 8
      Thanks, i think it reads "STM8309 81343"
      Any idea how i would go about test that component ?
        Need to look up the spec sheet to get the pin out of the Gate, Drian, and Source of the MOSFET so you check the resistance of those pins in combination.
        S to D
        S to G
        G to D
        • AdamJ
          • Aug 2013
          • 8
          http://pdf1.alldatasheet.com/datashe...P/STM8309.html
          Any idea of the range of read outs i should be seeing ?
          S1 to D1 (both) - 341k
          S2 to D2 (both) - 337k
          S1 to G1 - 421k
          S2 to G2 - 10k
          G1 to D1 (both) - 0.815m
          G2 to D2 (both) - 345k
            They are not shorted out or has low Ohm readings, so looks OK.
            • AdamJ
              • Aug 2013
              • 8
              Actually, the only one that has a off reading compared to the others is the 2nd chip and S2 to G2, its reading is 5.7
              Does that look like my problem ?
                If it reads 5.7 Ohms, that is bad, and since you also had blown the fuse that feed the voltage to the MOSFETS something was shorted. You may want to check the fuse again.
                • AdamJ
                  • Aug 2013
                  • 8
                  I'm trying to match up a replacement MOSFET but i'm not sure which one.... http://uk.rs-online.com/web/c/semico...ock=4294957913
                  I've filtered the required spec according to the spec sheet and got it down to 2, but which one ? Of course these might not be compatible.
                  Or these 2: http://uk.rs-online.com/web/c/semico...ock=4294957828
                  Cheers,
                  Adam
                    The pin out have to match.
                    Voltage and Current handling has to be the same or higher, not lower.
                    RdsON should be really close or lower, slightly higher will be OK (it will run hotter with higher RdsON). Vgs in the same range. Same or higher power dissipation.
                    DMC3028LSD is really close, it should work.
                    • AdamJ
                      • Aug 2013
                      • 8
                      I've managed to get a STM8309, its on its way.
                      Looks like its going to be very difficult to swap this out, its so tiny !
                      • Rtech
                        • Jul 2010
                        • 1095
                        One thing to do,is to add solder,before unsoldering.
                        • wobbin
                          • Apr 2013
                          • 18
                          That's an easy swap really. RTech's suggestion of adding more solder first is a good one.
                          Cut he pins close to the chip with a sharp knife first. You only need to remove one pin at a time then and there's less chance of lifting a track with too much heat.
                          Tack each corner pin down of the new chip and then apply liquid no clean flux fluid and drag solder across the pins. If any pins are bridged with solder accidentally, simply apply more liquid flux and drag a clean soldering bit over the pins and the excess solder will come away. Or you can use solder wick to remove excess, whichever you find easiest.
                          HTH
                            I hope you order more than 1 MOSFET, I always replace both of them together.
                            • AdamJ
                              • Aug 2013
                              • 8
                              Thank you Badcaps !!! Its fixed and working !!
                              Special thanks to budm for his expert input and suggestions !
                              Cheers guys !
                              • Kjell
                                Samsung Series 9 - BIOS issue
                                by Kjell
                                After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                08-01-2025, 09:15 AM
                                09-07-2024, 05:50 AM
                              • Nairolf
                                Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                by Nairolf
                                I have a Samsung DM32D display.
                                When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                Here’s what I have tried so far:
                                1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                08-24-2025, 03:47 AM
                              • vincentedel
                                Samsung SyncMaster 740n Phase Control Issue
                                by vincentedel
                                I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                04-22-2025, 12:33 AM
                              • Manucsl
                                QE65Q800TATXXC Samsung TV Issue
                                by Manucsl
                                Hello.
                                My TV is a QE65Q800TATXXC Samsung TV.
                                Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                Any ideas to check would be very appreciated 😊
                                After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                02-19-2025, 07:47 AM
