Screen white out when powered off.
  • steenamaroo
    • Aug 2013
    Hi everyone..
    This is my first post here; Looks like a great community.
    Before we start, I have a basic electronics knowledge and wiring/soldering skills, but I'm not trained or educated in this.
    Speak slowly and point just for safety! :p
    The issue is with my Father's Octigen 19" widescreen, which is connected to his mac mini.
    The mac sleeps at night.
    I had a range of symptoms over a few weeks, so please bare with me.
    Stage one:
    Waking the mac from sleep would show pure white output on screen.
    I proved the fault to be with the screen, not the mac.
    Usually reboot or re-sleep/wake would kick the screen back into life.
    Stage two:
    Finally the backlight stuck on permanently whether the screen was off or on, so I opened it up and clean/reconnected all connectors.
    No good. I just wrote it off and forgot about it.
    A week later I powered on out of curiosity.
    Stage three:
    Next it starting showing symptoms of failing PSU caps.
    It wouldn't even light up for me; It just clicked and PWR LED and backlight blinked every few seconds.
    I've seen and repaired this before, so I set about recapping the PSU.
    I replaced all electrolytics on the board.
    That was today and as soon as I reassembled it the screen worked, but the backlight would remain lit if I powered off the screen.
    This would happen with or without video input cable.
    After a few power cycles it actually starting behaving perfectly normally.
    Now it behaves normally with one exception. When I shutdown the computer, the screen just about blinks a tiny bit for a few seconds before properly shutting off.
    It's barely noticeable in terms of how bright it is, but will gradually speed up and then cease.
    I don't remember the last time my Father shutdown his Mac Mini. Maybe the screen always did this?
    Anyway, I thought I'd ask while it's convenient to carry out work.
    Any ideas or thoughts are appreciated.
    PS:I don't really care at all unless this is symptomatic of something that will just deteriorate over time.
  • harp
    White screen repairs
    by harp
    To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
    Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
    On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
    05-13-2024, 03:43 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • EazyBone
    Sharp LC-65Q620U White Screen
    by EazyBone
    Another TV topic!!
    I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
    The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
    Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
    08-21-2024, 12:56 PM
  • hcinne
    Dell G15 ryzen edition black screen 2 amber 1 white
    by hcinne
    I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
    07-23-2024, 07:56 AM
  • Chrissygizmo
    Panasonic TX-48CX350B backlights but white screen , blank screen
    by Chrissygizmo
    Hi all, I’ve got a problem I hope someone can help me fixi.
    I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
    01-11-2025, 03:18 PM
