Dell 3008wfp PSU problem
--- begin sig file ---
--- end sig file --- -
Re: Dell 3008wfp PSU problem
Pin | Good PSU | Bad PSU
P801 (to a/v board)
- 5.15 | 5.11
- 5.14 | 5.11
- 5.14 | 5.11
- 5.14 | 5.11
- 5.14 | 5.11
- 0 | 0
- 0 | 0
- 0 | 0
- 0 | 0
- 0 | 0
- 18.18 | 19.1 > 19.65 > 19.18 > 19.71 > 19.21 > 18.8 > 19.18 > 18.86 (across about a minute)
- 0 | 0
P802 (to a/v board)- 2.56 | 2.56
- 3.27 | 3.26
- 2.98 | 2.97
- 2.97 | 2.97
- 0 | 0
- 0 | 0
- 0 | 0
- 12.82 | 12.32
- 0 | 0
- 5.18 | 5.14
P803 (to inverter)- 24.3 | 25.1
- 24.3 | 25.1
- 24.3 | 25.1
- 24.3 | 25.1
- 24.3 | 25.1
- 0 | 0
- 0 | 0
- 0 | 0
- 0 | 0
- 0 | 0
- 0 | 0
- 3.26 | 3.26
- 2.56 | 2.55
- 0 | 0
The only voltage that fluctuates is Pin 11 on P801, all others remain constant. I was unable to verify the panel was in fact blank when testing (read above) but I believe it was due to the power led flickering once, which is the only other noticable condition.
Thanks.Last edited by leapius; 06-14-2013, 03:48 AM.Comment
First, the reason for asking for measurements in the exact format is we get the raw data without filtration and interpretation. Too often, we get people posting here saying "the voltages measure good" only to find out they were bad or out of specification or they miss reporting a key voltage pin. With raw data, we can see for ourselves.
Second, a multimeter only reports the quantity of the voltage, not the quality. The fluctuating 18V could have lots of ripple which may be causing a problem. As an example, see this article
http://www.jonnyguru.com/modules.php...Story4&reid=71
and the 12V rail.
Since you have fluctuating 18V, I suggest changing out the caps on this rail to see if you get a solid 18V.--- begin sig file ---
--- end sig file ---Comment
I get what you're saying. What tactic should I use to trace this 18v rail backwards and associated capacitors? I was trying to follow the trace visually but it becomes very difficult quickly. My limited knowledge about capacitors is that their purpose is to smooth voltage, so in seeing this fluctuation made me think that could be where the problem lies. My theory as to why the PSU is staying on but the screen goes blank was that it was sending fluctuating voltage to the a/v board and that it didn't like so shut down (and cascaded that to the tcon and then to the inverter).Last edited by leapius; 06-14-2013, 05:32 PM.Comment
Put one probe on the 18V pin. Put the other probe on the + leg of the capacitor. If the multimeter beeps, it is on the 18V rail.
In addition, the caps on the 18V rail are likely to be 25V or 35V rated. Thus, no need to check the caps rated at 5V, 10V or 16V.--- begin sig file ---
We invite and want people thinking and interpreting the raw data, but we would like to confirm.--- begin sig file ---
Continuity beep mode on your multimeter is your friend.
In addition, the caps on the 18V rail are likely to be 25V or 35V rated. Thus, no need to check the caps rated at 5V, 10V or 16V.Comment
I have now replaced the two capacitors (new Rubycons) that I found on the 18v rail and the voltage still fluctuates between 18.8~19.7 seemingly randomly but after a while it settles down. It tends to go high on cold start and then slowly drop back down.
What can I try next? Re-cap the whole board?Comment
One of the 3 pin schottky diodes, probably mounted on a heat sink, is likely responsible for generating the 18V. See if it is stable 18V DC (likely the middle pin).
If it is, then you have to trace the path from that diode to the 18V connector on the board. Something in the 18V "path" could be bad. Since you replaced the capacitors, you can rule them out.Last edited by retiredcaps; 06-18-2013, 03:58 PM.--- begin sig file ---
Of the 5 diodes on the heatsink:
2 are at 25.2v constant
2 are at 5.17v constant
1 varies 17.77~17.58v (and dropping. This is the notorious D22 schottky - voltage seems to go slowly in the downward direction)
That was the only one close to 18v. As you can see it's not producing the same voltage as the output pin. Is that variance of interest?Last edited by leapius; 06-18-2013, 04:44 PM.Comment
It wouldn't hurt to change it since it has been problematic for many people. Eventually, it will fail like so many others have reported.--- begin sig file ---
Do have a schematic for this PSU? If not, you will have to trace out all the components on the rail .--- begin sig file ---
I've not found one as of yet but could you give me an idea of how to do this myself? Also do you know what failing components are likely causes for voltage fluctations like this? Thanks.Comment
I am having a lot of trouble tracing the rail back using the continuity method. Nothing seems to be connected. If the D22 has a voltage 17.59~17.77v does that mean it is on the 18v rail? Because the continuity beep is not present. I can only make it beep on 2 capacitors in fact.
Also does this flucation indicate the problem is further down the line towards the transformer? Or could the diode itself be causing a fluctuation? ~0.2v fluctuation is not as much as the ~1v difference seen at the pin itself.
Many thanks for any help.Last edited by leapius; 06-20-2013, 03:27 AM.Comment
by Borse2008Hi everyone,
Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:- The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
- There’s
07-15-2025, 04:55 AM -
by spike3333Hello,
I have a Dell 3008WFP monitor that I disassembled to replace any bad capacitors. After reassembly, the monitor turns on but immediately starts to cycle through simple colored screens; red, yellow, blue, black and white. From my internet search it appears that the monitor has entered a "burn in" mode. I tried all the different button push combinations that were recommended to enter a service menu but none worked. My question is, could this be caused by a hardware issue; an improperly seated connector or something else. Does anyone else have any experience with a...-
by SDNarciaHello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
As additional information,... -
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by Achille15Hello everyone,
so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be... - Loading...
