Monitor PSU circuit board question
  • Davejr
    • Jun 2013
    • 16
    What are these? (As noted with the red lines pointing)
    And, is it absolutely imperative to maintain this gap? (as noted with the black lines) [also note that the blue dots indicate the leads of one of the capacitors that I will be replacing]
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Monitor PSU circuit board question
    It's not imperative to leave the gap but I think it's best to leave it how it came, with the solder maintained
    • mariushm
      • May 2011
      • 3799
      It's just extra solder applied on the copper traces so that the pcb can carry more current through the traces.
      copper trace heats less due to more metal on it.
      The black lines (and the coating over the traces) are there as a sort of blocking mechanism so that the solder attaching to the lead won't just get in contact with the other solder, the island on the trace. If it did happen during soldering, the solder on one side could suck the solder on the other side, for example the lead on that component could be poorly soldered because the solder moves to that island of solder.
      • Davejr
        • Jun 2013
        • 16
        I added those parallel black lines in photoshop to aid in the question. That gap, and several others, is extremely narrow. Keep in mind that the lead spacing on the caps is 3.5mm for reference.
        • mariushm
          • May 2011
          • 3799
          I didn't even think about it. Sometimes there are such lines on pcb made using silkscreen.
          The idea remains the same.
          Picture it like this. The board is sprayed with a liquid flux, then it's attached to a conveyor belt by the corners and goes inside a machine, over a bath of liquid solder.
          Anywhere there's flux and bare copper, the liquid solder comes up and gets attached.
          There are however things such as surface tension and other. Basically after solder covers the whole copper island on the trace, it tends to shrink towards the center of the trace reducing its size. If there was no separation between the round pad and the copper island, the solder could go towards the solder island and the lead of the component could be partially unsoldered or poorly soldered.
          Also, there's an issue of the larger copper trace dissipating heat better (so there's more time required for solder to adhere to the copper) compared to the round pad and the lead.
          On the round pad and lead, solder heats them up fast and goes up the lead and forms a nice solder job on the bottom and the top (if it's a double sided board). With the large copper traces, it takes more time for the solder to cool down and solidify.
          If they were together in a large blob, the component soldered there could be affected from the heat of the chunk of solder cooling down on the traces.
          Here's a good example of how these boards are soldered : http://www.youtube.com/watch?v=inHzaJIE7-4
          • Davejr
            • Jun 2013
            • 16
            So I just need to solder as carefully as I can, but if I should accidentally 'bridge' that super tiny gap it shouldn't blow it? All the vids I've watched on youtube make it look easy without that much precision in the soldering.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Yeah you will be fine.
              It depends on the board somewhat too, and the solder that you use.
              • lexwalker
                • Feb 2011
                • 307
                • Malaysia
                Those actually have two functions. For the first one, they act as passive heatsink on the PCB (to dissipate the heat). For the second one, it allows more current to flow thru the traces (you can commonly see this in high current computer PSUs also)..
                • Davejr
                  • Jun 2013
                  • 16
                  Thank You! You guys have been very helpful.
                  • Lumberjack777
                    • 464
                    OK, they answered the other question but to answer this question....
                    The black lines are on the same copper trace or conductive pathway (inside the red). You don't have to worry about a "gap" there. In fact if a person was to lift a trace where the component is soldered in; they might need to connect to a component nearby on the same copper trace or conductive pathway.
                    BUT......where you have the 2 blue dots for the leads for the capacitor: that gap needs to be maintained. You'll notice they are on 2 different copper traces. Hope that helps.
                    • Davejr
                      • Jun 2013
                      • 16
                      Thank you Lumberjack777. Yes it does. My soldering skills are 'ok', but I'm not a robot. That extremely narrow gap had me concerned when I was examining it. Used macro mode on the camera to take the pics. I do plan on practicing a bit.
                        by momaka
                        03-15-2023, 10:17 PM
                      • penangit
                        Hp v193 monitor power supply board
                        by penangit
                        Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                        I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                        I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                        Steps taken so far:
                        Checked all...
                        02-21-2023, 04:00 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • repair-it
                        Engineering help - how does the charging circuit on this board work?
                        by repair-it
                        This board attaches to 2 12v batteries in tandum (Black/Red squares). There is a 24v power supply that attaches at the 2 pin molex connector (circled in red). I need help to determine which components run the charging circuit in an effort to determine a point of failure. There are multiple via's, making it difficult to trace the circuit. Nothing appears to be shorted but I wasn't able to fully test as I do not have 2 12v batteries available. My assumption is that the micro controller (red question mark) determines when to turn the charging circuit on & off. I'm pretty sure a regulator and...
                        08-31-2024, 12:32 PM
