TOSHIBA P200 ISRAA-LA-3441P Blank screen issue
+ More Options
Posts
  • oxonater
    • Oct 2012
    • 77
    • uk
    Toshiba Satellite P200-1EE
    Model no:PSPB6E-0GMO28EN
    Mainboard:ISRAA-LA-3441P REV 2B
    The issue is the LCD is blank and only get a mere flicker of screen as laptop continues its boot up process. I have changed the Inverter and no joy, I have a working backlight out of a smashed screen and when connected into the above mentioned Inverter it doesn't light up at all I have tried 2 still no joy. The laptop will work fine when connected to an external display. If anyone has had a similar issue any help would be greatly appreciated. I have the schematics but have little circuitry understanding any help on this would be great or a point in the right direction thanks.
  • malangg
    • Sep 2014
    • 34
    Re: TOSHIBA P200 ISRAA-LA-3441P Blank screen issue
    hi..same problem here,..any help plz
      master hoarder
      • May 2008
      • 12175
      White screen problem is either bad LVDS connection to the T-con board or bad boost-buck / charge pump circuit on the T-con board.
      Start by re-seating all connectors.
        Toshiba Satellite Pro P200-14W Specification for Upgrade or Repair
        This specification for the Toshiba Satellite Pro P200-14W can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P200-14W boardview and P200-14W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
        09-06-2024, 05:27 AM
        Toshiba Satellite Pro P200-15E Specification for Upgrade or Repair
        This specification for the Toshiba Satellite Pro P200-15E can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P200-15E boardview and P200-15E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
      • harshana
        DA0ZPVMBAD0 rev d Mainboard - blank screen issue
        by harshana
        I have the DA0ZPVMBAD0 rev d logic board and it doesn't boot up. I see all the voltages are okay. So I suspect the issue is bios.
        When I power on with fn+ esc the blue light start blinking on mainboard.
        I guess its a good sign. As all the voltages are okay and also charging indicates orange light when battery connected, I think it confirm that the EC bios is okay. So I ignored the ec and flashed main bios with 32mb bin file provided in the link below. But the condition is same.
        https://www.badcaps.net/forum/troubl...and-electronic...
        08-16-2025, 02:16 PM
      • wizard13
        Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
        by wizard13
        I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
        I have checked the forum and the available documentation but could not find a solution specific to my issue.
        • Brand & Model: Dynabook Satellite Pro C50D-B-100
        • Part Number (P/N): PYU13E-00C00PFR
        • Serial Number (S/N): 22028896H
        • System Configuration (SC): A1PYU13E1127
        • Motherboard Model: IP3_ACN16_MB_V21_20211222A
        • Power Input: DC 19V –
        02-28-2025, 02:43 AM
      • Russ17
        Toshiba 43L3753DB Screen Issue
        by Russ17
        Hi
        I have a Toshiba 43L3753DB.
        When turned on, the Toshiba Logo is distorted and unreadable, but once the TV is booted, pressing the "Menu" button gives a visible menu, but if you try to select any menu, the screen becomes unreadable. The No signal message is readable and so is the info bar at the bottom of the screen, it just seems that as soon as there is a requirement to provide an image across the entire screen, it becomes unusable.
        When the screen is unreadable, the PSU noise increases.
        The 12V is good (12.14V) and is present...
        11-19-2020, 04:36 PM
