Viewsonic/DGM/Digimate Monitor flashes for 2 seconds then off!
  • rash.m2k
    • Apr 2010
    • 64
    Hey folks,
    I've got a DMG 24" monitor bought from ebay, the user said it was working fine and then it just started to show lines on the LCD.
    So I grabbed it opened it up and saw clearly two bad caps, plus a third that was the same make (and identical farad and voltage), so I replaced all three. In the process however I seem to have snapped the board that contains the buttons!
    Now the LCD just flashes on for about 1 second (all seems perfect image wise), then goes black. This happens when power cable is re-plugged and ALSO when the DVI cable is re-plugged in also.
    Since the buttons are broken a little multimeter check showed the buttons are high and each button takes the line low to trigger it.
    Since I have it disassembled, I can hear a high pitched noise when the monitor powers on, it then disappears for a few seconds (while the LCD backlight is on) and then re-appears once the panel switches goes black (and stays there), once I unplug from mains the sound seems to wind down slowly.
    So folks your help on getting this fixed would be most welcome! It's an extremely nice LCD and only reason I bought it is for sentimental reasons, I had the exact same panel a few years ago and had to sell.
    Monitor also goes by the name of Digimate, Yuraku but is acutally a Viewsonic Optiquest Q241wb.
    The full schematic is here:
    https://www.box.com/s/mtulxa4od8doiulm0du7
  • rash.m2k
    • Apr 2010
    • 64
    Re: Viewsonic/DGM/Digimate Monitor flashes for 2 seconds then off!
    pictures of the power board:
    https://www.box.com/s/9r8h8nalopf5mzj2banz
    https://www.box.com/s/nhd7s48wpyy00z8e6nsf
    https://www.box.com/s/8ztl1ym5ssfbs8tqlb3n
    • selldoor
      Slow Learner
      • 7870
      Please update your profile with country and mains voltage.
      Please re post your pictures using manage attachments - may get more members to view them - better still re take them as follows
      Test the secondary windings on each of the small transformers.
      Welcome to the forum-
      We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...7&d=1280167246
      https://www.badcaps.net/forum/attach...6&d=1280167246
      https://www.badcaps.net/forum/attach...4&d=1280167246
      • rash.m2k
        • Apr 2010
        • 64
        Ok I'm in the UK and my mains voltage is 240v. Although I can solder I'm not a electronic engineer, but not afraid of getting stuck in with electronics.
        Whan you say 'small transformers' do you mean the black ones on the left? I have a digital multimeter so can check the voltage of these - what should it be?
        • leapius
          • Aug 2012
          • 60
          You should check the resistance across each of those transformers are all the same. One or more that is different from the normal usually indicate a bad one.
          • rash.m2k
            • Apr 2010
            • 64
            Lol folks you are not going to believe this, turns out I had bent the inverter pins. Straightened them out and all working now!!!!
            • selldoor
              Slow Learner
              • 7870
              What inverter pins?
              • rash.m2k
                • Apr 2010
                • 64
                Originally posted by selldoor
                What inverter pins?
                On the left hand side in the first picture, the white connectors (above and below where it says ABCDE FGHIJ), the pins inside the connectors where the inverters plug in were bent - so one pin would make contact and not the other, so a complete circuit would not be made.
                I straightened the pins and voila! Working!
                • selldoor
                  Slow Learner
                  • 7870
                  Thanks - those are the lamp sockets.
                  Something else for us to look out for
                  It is usually the lamps or the transformers, we tend to overlook the
                  connector.
                  • Rick_1234
                    LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                    by Rick_1234
                    Good evening, gentlemen.
                    I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                    To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                    https://drive.google.com/file/d/1L6S...ew?usp=sharing
                    Things I tried
                    - Bought a new AC adapter thinking that was the problem but the problem...
                    06-22-2024, 04:44 PM
                  • sew333
                    Pc shutdown, monitor flickered with no signal after 10 seconds
                    by sew333
                    My pc:
                    10850K stock 4800mhz stock Kraken X73 good temps
                    2x16 GB DDR4 GSKILL 3000mhz XMP
                    Seasonic Tx-850 Ultra Titanium
                    Gigabyte Rtx 3090 Gaming OC
                    Aorus Z490 Pro Gaming
                    1 TB SSD
                    4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                    Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                    Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                    Power...
                    02-22-2022, 10:27 AM
                    by momaka
                    03-15-2023, 10:17 PM
                  • cajoeg
                    Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                    by cajoeg
                    Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                    The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                    02-10-2025, 04:01 PM
                  • wattage
                    AOC AG493UCX 49-inch monitor - Firmware request
                    by wattage
                    Hello Badcaps Community,
                    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                    07-13-2025, 04:41 PM
