hp 2210m monitor no power
  • ttt9090
    • Apr 2013
    • 16
    • canada
    Can anyone offer some advice on where to begin tests on this monitor?
    Will not power on at all.
    Thanks in advance
    Re: hp 2210m monitor no power
    Start by uploading GOOD CLEAR pictures of the boards using attachment function, do not post the pictures in line.
    • retiredcaps
      • Apr 2010
      • 9271
      Look at budm's Baisc LCD TV and Monitor troubleshooting guides link above.
      --- begin sig file ---
      --- end sig file ---
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
        03-31-2024, 02:12 PM
      • mikey5791
        Philips 196V3L monitor power led off
        by mikey5791
        Hi, i was given this lcd monitor last week with the issue of power led blinking. Upon checking the power board, i found 2 pieces electrolytic caps bulged and replaced them.
        Later, when i switched on ac power and detected 5v and 15v dc at output pins. But as soon as i pressed on the front power button, the led on power button lights for 1 second and it turns off.
        So, i tried disconnect the flex ribbon cable from t con board. But all i got is a white screen with nothing on. I suspect there is something short somewhere that prevent the display being turned on. Can someone with...
        01-25-2024, 07:52 PM
        09-06-2024, 05:59 AM
