Samsung syncmaster 305t blank monitor, no light from the power LED
  • JEBONE
    • Aug 2012
    • 7
    • Sweden
    I have a bought an out of order Samsung Syncmaster 305t cheap in the hope of being able to fix it. The problem is that when connected to the AC outlet it would not start, and the LED on the power button does not light up.
    I have picked apart the screen and when checked the power supply I saw that the large capacitor (450v, 150uF) was bulged. I then replaced the capacitor with the same values, even the remaining capacitors are replaced with new ones. Then I put together the display and connected to the outlet, nothing happens, still black and the start button does not light up.
    I have the six new capacitors to the inverter board but have not put them there yet. Is it possible that it may be faulty?
    The power board: BN96-03938A if it helps.
    I have include a picture of the power board.
    Any idea about what I should look at next?
    Tanks,
    Jon Brodén
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung syncmaster 305t blank monitor, no light from the power LED
    Pictures need to be a little sharper for troubleshooting - we need to be able to read what it says on the board. Have you tested the 3 fuses? 2 white near the mains and a green torpedo one in the middle of the board.
      I will first find out if you are getting the standby 5v (or 3.3v) voltage first, it is generated by the smallest yellow transformer close to the heatsink.
      Are there any labels on the power supply connectors.
      This power suply also has PFC Voltage booster circuits, the voltage on that large cap should be around 160vdc, then it should go up to around 390VDC when power switch is activated.
      No blown fuse?
      • selldoor
        Slow Learner
        • 7870
        Budm he is in sweden so voltage on cap will be around 325vdc? to start with
        • JEBONE
          • Aug 2012
          • 7
          • Sweden
          Tanks all for the quick replies!
          added some new pictures that might be better.
          The other two fuses are intact.
          Is it the green thats looks like a resistor where the large capacitor is? measured it with ohmmeter over the fuse and the measured zero ohms, or do I need to solder away and measure to be correct?
          I have a red ring around that I believe are the green torpedo fuse in the first picture.
          No blown fuse?
          I measured the small yellow transformer on the secondary side, the measuring between 3.4-3.7V
          Do I need to take some precautions when to measure the high voltage?
          Should I measure in parallel over the the large capacitor?
          In the fourth and fifth image is of power supply connectors.
          from top to bottom on the picture it says GND, 5.4V, 1.8V, GND, N.C, GND, 24V. on the fourth and the fifth picture from top to bottom in the picture 6.0V, GND, Power on / off.
            "top to bottom on the picture it says GND, 5.4V, 1.8V, GND, N.C, GND, 24V. on the fourth and the fifth picture from top to bottom in the picture 6.0V, GND, Power on / off."
            So what voltages do you get at those pins, black probe on the chassis (cold side circuit's ground), red probe on those pins.
            • JEBONE
              • Aug 2012
              • 7
              • Sweden
              GND, 5.4V, 1.8V, GND, N.C, GND, 24V: I get only a few mV on each output.
              6.0V, GND, Power on / off: 6.0V output, I get 6V and Power on / off, I get a few mV and when I press the power button at the front, I get 3V
              • selldoor
                Slow Learner
                • 7870
                Yes that is the green fuse if it measures 0.00 ohms it is good .
                • selldoor
                  Slow Learner
                  • 7870
                  Is that with all boards connected?
                  • JEBONE
                    • Aug 2012
                    • 7
                    • Sweden
                    Strange now that connected everything together connected AC outlet, started the monitor, but it is flashing red, green, blue, gray and off, red, green ..... loops around so.
                    has now also 5.4V, 18V, 24V on outputs.
                    Is it possible that main processor chips that are faulty or?
                    • selldoor
                      Slow Learner
                      • 7870
                      Have you got a source connected the rbgw may be a self test that displays instead of
                      "NO Signal"
                        OK, so this power supply board has 6v for standby power supply, the 5.4v, 12v, 24v are switched on when PS_ON (POWER ON/OFF) goes >3vdc.
                        But right now it powers up OK. You may want to check solder joints, etc, on the power board.
                        • JEBONE
                          • Aug 2012
                          • 7
                          • Sweden
                          Thought Iwould notify the screen works fine now. maybe I'll check solder joints if it would die again.
                          Thanks a lot for your help everyone
                          //Jon Brodén
                          • Habtay
                            • Oct 2013
                            • 3
                            I have the same problem with exactly the same PSU, no power at all on the secondary side of the small yellow transformer. There is power on the primary side (80V relative to ground, 165V across) any help is highly appreciated. I can use a digital meter and soldering iron but not sure how the power supply circuit works.
                            • Habtay
                              • Oct 2013
                              • 3
                              No blown fuse?
                              Hi there,
                              I am a new member and I have the same monitor with the same problem up to this message, on mine I'm not getting the 5v or 3.3v, no volt at all on the secondary side of this transformer. There is power on the primary side of this transformer. there is also power on the big capacitor (150uF, 450v) 165v.
                              Can some one please direct me on what to look next.
                              • MikeBeachBum
                                • Oct 2014
                                Hello all,
                                I get a lot of information from these forums so I would like to help anyone who had the same problem as I did.
                                Samsung 305T
                                Absolutely dead, no lights anywhere on the system.
                                My first thought was either fuse or cap. These monitors, while beautiful, have a poor reputation for heating up. Anyway, I opened it up (very easy to do btw) unscrewed the power supply, put it on a bench. The fuses checked fine. I plugged it in and looked at various voltages. All the voltages I checked (maybe 10 points) looked fine. Hmmm... So I plugged it back in, flipped on the toggle switch next to the power plug, and the blue light on the front power switch came on. I put the unit back together, put it back on my desk, plugged it in, no blue light. Repeated the whole process over again, and it appears to be one of the four ribbon cable connectors that go into the power supply. I don't know which one, but if I carefully made sure that they were are seated firmly, the unit would power on reliably. Anyway, no the most scientific debugging, but I'm hoping it helps someone somewhere.
                                  09-07-2024, 05:50 AM
                                • Kaar3l
                                  Samsung QLED QE65Q7FNAT only standby light
                                  by Kaar3l
                                  TV: Samsung QLED QE65Q7FNAT
                                  PSU: BN4400940A
                                  MB: BN94-12832K
                                  I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                  09-24-2024, 01:35 PM
                                • marcinq
                                  Samsung UE60KS7000 No Standby Light
                                  by marcinq
                                  I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                                  I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                                  05-26-2025, 11:36 AM
                                • ChristianBr01
                                  LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                  by ChristianBr01
                                  I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                  The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                  What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                  04-23-2025, 01:48 AM
                                • DXseekerMO
                                  Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                                  by DXseekerMO
                                  Hello everyone!
                                  Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                                  Symptoms:
                                  1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                                  2) TV does not appear to turn on
                                  3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                                  4) "Power on" terminal on Power Supply has 3.26v
                                  5) "A13V" terminals have 12.9v
                                  6) Stand-by test jumper on Power Supply has 12.9V
                                  7) Optical audio jack on Main Board illuminates
                                  8) With stand-by...
                                  06-09-2021, 12:19 AM
