Hi, I have an optiquest q19wb with a green tint on the screen. I walked out of the room for 3 or 4 minutes and by the time I came back it was green. I've checked the usual cables and ports, it's definitely an issue with the monitor. I've looked around and found guides on the internet that show how to replace capacitors on the main board. I was wondering if the issue is actually with the main board though, and if it's not, is there a place to buy a replacement video board or instructions on how to diagnose and repair the video board? Thanks!
Optiquest q19wb green tint
Tags: None
Re: Optiquest q19wb green tint
Is there a factory reset in the menu
What happens when you adjust the color.
Have you tried the monitor on another pc -thinking graphics card.
Inside there is a cable from the main board to the panel have you cleaned/reseated both ends.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
Thanks I wasn't expecting a reply that quick
I just took a look to see if there was a reset, I didn't see one in any of the options.
When I adjusted the colors, red and green would do something,I assume it was adjusting those levels, but the blue did nothing, so I'm assuming that blue is missing completely.
I checked everything when I opened it up, there's nothing that seems out of ordinary, only a hard press will get any of the connectors to wiggle, and the vga connectors on the cable were all seated and snug. Ive tried the monitor on a couple computers and it does the same thing.Comment
Maybe a problem with a voltage regulator on the main board.
See guide on 2 seconds to black sticky at the top of this forum start at post19.
We can sometimes help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
https://www.badcaps.net/forum/attach...7&d=1280167246
https://www.badcaps.net/forum/attach...6&d=1280167246
https://www.badcaps.net/forum/attach...4&d=1280167246Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
