Dell 2407WFPb shuts off after 90 minutes
  • sgt_az
    • Jul 2009
    • 9
    I have two Dell 2407WFPb monitors that shut off after 90 minutes or so and need to be unplugged and plugged back in to restart. Both monitors will run all day with the back cover off for troubleshooting. I've read through the threads on repairing these monitors when they completely die. I'm hoping to correct the problem before there is the typical catastrophic component failure when the 120uf 450v capacitor fails.
    I've pulled most of the electrolytic caps and tested them with an ESR meter and most look to be well within spec. I've ordered replacement capacitors to completely recap all three boards in these monitors anyway. Does anyone have a suggestion on what to look at if replacing the capacitors doesn't cure the thermal issue? I've checked all heat sinks, solder joints, and wire connectors already. Suggestions would be greatly appreciated. Thanks.
  • jetadm123
    • 2169
    Re: Dell 2407WFPb shuts off after 90 minutes
    Since they work fine with the back cover off, it sounds like a heat related problem. With the monitor running, try heating up each board with a hair dryer to see if you can get the monitor to shut down. This should hopefully isolate which board/area is causing the problem.
    • sgt_az
      • Jul 2009
      • 9
      Update. I was able to get all of the replacement capacitors through Mouser.com. Ended up using a 420v 120uf capacitor to replace the 450v 120uf capacitor on the power supply board. I replaced all of the capacitors on just the power supply board to start with and so far both monitors have run for 24 hours without shutting off. If this holds up the fix will have consisted of: one 420v 120uf cap, five 35v 470uf caps, one 25v 220uf cap, two 50v 47uf caps, and one 100v 1uf cap.
      Mouser part numbers:
      120uf 450v ----> 120uf 420v Mouser.com pt# 647-UPTW6121MHD QTY 1
      470uf 35v ----> 470uf 35v Mouser.com pt# 667-EEU-FR1V471B QTY 5
      220uf 25v ----> 220uf 35v Mouser.com pt# 647-UHV1V221MPD QTY 1
      47uf 50v ----> 47uf 50v Mouser.com pt# 647-UVR1H470MED1TA QTY 2
      1uf 100v ----> 1uf 100v Mouser.com pt# 647-UVZ2A010MDD1TD QTY 1
      • huzo
        HP Omen shuts down when loading OS
        by huzo
        The model is 15ec-1061nm
        Board number is DAG3EDMB8D0​
        SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
        10-29-2024, 12:05 AM
      • brav1ez
        ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
        by brav1ez
        I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
        I’ve tried:
        - CMOS reset
        - Removing the SSD/HDD
        - Reseating RAM (removing each stick individually stops boot completely)
        - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
        With...
        09-07-2025, 10:47 AM
      • chaos-theory
        Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
        by chaos-theory
        I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
        Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
        03-14-2025, 05:37 PM
      • baglaivlad
        A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
        by baglaivlad
        Hello everybody!
        Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
        After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
        11-20-2024, 08:14 AM
      • samuelphirik
        Dell inspiron 15 7567 sudden shuts down
        by samuelphirik
        Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
        During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
        I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
        Now I've noticed that laptop...
        07-02-2023, 05:45 AM
