Opening the Case of a Dell 2209WA
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • kleung
    Dell ultra 7070 ,Foxconn PWM laptop case fan. Spins at 100% speed in failure mode.
    by kleung
    I wanted to add to the knowledge base about a PWM case fan that it can fail at 100% speed.
    On my Dell ultra 7070 (this is a 0.6 L pc so uses laptop parts); I had the case fan suddenly go 100% and I couldn't control it. I disconnected/reset bios and it was only solved when I swapped in a replacement fan.
    I have tested and there is continuity between the 4 wires pins and the circuit board.
    That is the extent of my troubleshooting. I took pictures of the circuit board but don't know what component would die (PWM controller?) that could cause this to happen....
    12-07-2024, 01:45 AM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
    ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
    This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 10:50 PM
    ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
    This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 11:05 AM
