Apple LED Cinema display 24 inch Testing power supply need some help
  • curt0012
    • Feb 2013
    Hi I'm new to the form. I've worked on electronics for many years but Testing capacitors is something new in my book. My problem is I'm testing the power supply on a Apple Cinema Display. I've confirmed from another website that is definitely the power supply. But when I started testing the capacitors the uf Are higher then the rating on the capacitor so what Does that means they're also bad. I don't think it's my new Multi meter is defective, because The other capacitors on the power supply I tested Are reading within the range. I'm confused of use the search still trying to find anyone else have this problem but I did not see that. I know that if the uf is lower than written on the capacitor I know it's bad but what about being higher. Thank you for any help that you can offer.
    Curtis.
  • opamp
    • Dec 2012
    • 160
    • united states
    Re: Apple LED Cinema display 24 inch Testing power supply need some help
    You are in the wrong forum, this is the "general electronics" forum. Try the 'troubleshotting computer dispalys" forum just below the general electronics.
    • jetadm123
      • 2169
      Are you testing the caps in circuit? If yes, then other components in the circuit could be affecting your readings. Top down photos of the circuit board would be helpful. Do not post them inline, use the "manage attachments" option to post.
      • a_p3rson
        Apple Watch Charging Controller Schematics / Boardview - 820-02601
        by a_p3rson
        Hi there,
        I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
        You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
        This daughterboard uses an interesting...
        04-21-2025, 11:41 PM
        by sam_sam_sam
        07-01-2024, 06:34 AM
      • CMCM
        Russound CA4 Power Supply Repair
        by CMCM
        Hello Everybody,
        Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
        Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
        The outputs marked 12v and 20v are all measuring only 1v.
        The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
        The capacitors physically look clean (no bludgesor leaks) and...
        07-03-2025, 01:12 PM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
