Benq power board failed, no backlight
  • supersabre
    • Feb 2006
    • 45
    I have a HP LCD monitor with benq power board. Last week, when i turned it on, the backlight turned off right away. I can see the image moving on the screen using flashlight.
    I found out the whole thing was made by benq and there 're some discoloration( lititle darker) near the transfomer .
    I borrowed a ESR meter from my friend and all the caps are still within range. I suspect it is the transisitor that near the transformer.
    The transistor is FU9024N , a p-channel transistor, and i only have a multimeter
    Anyone know how to to test it using the multimeter?
  • VILE DISRUPTION
    • Jun 2006
    • 47
    Re: Benq power board failed, no backlight
    Well you can find a few transistor test methods out there. i always skip them because my multimeter has a nice little feature where you slot the transistor in a socket and switch it to "Transistor test" mode. look around and you should fine one.
    Stats Reset Every Month.
    My Forums
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • C152Heavy
      Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
      by C152Heavy
      Summary for TL-DR readers:
      • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
      • Have obtained Samsung schematic & service documents - Can upload if helpful.
      • Have read ALL applicable threads
      • C1818 and CP820 replaced as low hanging fruit
      • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
