Belinea 101715 (help for identifying zener diode)
+ More Options
Posts
  • srbax
    • Nov 2012
    • 78
    • Serbia
    Happy New Year and very best to all!
    I hope I wrote this correctly
    On power board of this Belinea 101715 (model 111717) monitor I found shorted mosfet (K2996), bridge rectifier, fuse and one smd zener diode.
    Mosfet pdf: http://pdf1.alldatasheet.com/datashe...996-TA3-T.html
    I can't find service manual for this Belinea model and I don't know how to determine zener diode specifications.
    I need Your help in identifying specifications of zener diode.
    Diode was on position Z101. On the same pins were resistor of 0.68 ohms.
    Like some other zener diodes on board it has only yellow ring without any other markings.
  • UniT3d
    • May 2011
    • 43
    Re: Belinea 101715 (help for identifying zener diode)
    Hmmm .....
    Service manual attached. I'm not quite sure about Z101 but I believe it should be TZX24B ... Hope that helps.
      Too bad that the service manual does not have the power supply diagram, that Znere Diode is in parallel with the MOSFET Source resistor, it is there to limit the voltage drop on the Source during startup, there is a voltage spike when the power supply is first turn on which can fault triger the Isense signal of the SMPS IC that monitor the current flowing through the Source resistor.
      Have to Google the pwoer supply board to find the diagram for it.
      When the MOSFET blow up, it will usually take the SMPS IC Gate drive circuit in side the IC and also the Gate drive resistors and Diode. You need to check them all carefully. Otherwise you will blow up your new MOSFET if the Gate drive circuit is stuck with steady High output condition. You can look up the spec of that SMPS IC, sometime they will have application notes showing how the circuits should be made, may be it will show the Zener diode in that app notes.
      See example SCH, in this drawing, it is ZD301.
      Most companies do not have this Zener in the circuit.
      • srbax
        • Nov 2012
        • 78
        • Serbia
        Thank You all for Your answers!
        Marking on SMPS IC is 203D6 and I found datasheet for NCP1203.
        I checked resistor and other diodes and they have correct values.
        Do You think that SMPS IC is also have to be replaced?
        Is it possible for this power supply to work without that zener?
          OK, lets test the IC resistance reading of all the pins of the IC between pin 4 (Ground) and the other pins to see what you get, make sure to tell us what it shows on the meter so we know for example 1 ohm, 1K Ohm, or 1M ohm.
          Then check the resistance between pin 5 (Gate Drive) and pin 6 (VCC) to make sure the internal is not shorted.
          The power supply will work without the Zener for now, as you can see in the diagram, they did not have the Zener at the Source of the MOSFET either.
          • srbax
            • Nov 2012
            • 78
            • Serbia
            pin54=296 Kohm
            pin64=216 Kohm
            pin74=0L
            pin84=367 Kohm
            pin14=22.5 Kohm
            pin24=41.2 Kohm
            pin34=0.54 Mohm
            pin56=429 Kohm
            • srbax
              • Nov 2012
              • 78
              • Serbia
              I was searching for service manual for this monitor and in this post https://www.badcaps.net/forum/showthread.php?t=21185 I saw that Viewsonic VE710b monitor has the same power supply board.
              Does anyone have service manual for this monitor?
              Model of power supply board is SLV0315A0450-00.
              • srbax
                • Nov 2012
                • 78
                • Serbia
                I think I found it, but there is no values for components:
                • terry
                  • Oct 2007
                  • 91
                  • Milton Keynes, Bucks
                  The power board on this monitor might help. http://linfotech.co.uk/schematics/Proview/Preoview 20LCD 20fv926afw.pdf
                  • unimatrix93
                    TV backlight zener diode
                    by unimatrix93
                    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                    The led strips has 9 6V leds.
                    02-10-2025, 12:13 PM
                    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                    by sam_sam_sam
                    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                    I bought this from an eBay seller but unfortunately they only had one
                    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                    I bought three of from them to also make battery packs with this output power limit in mind
                    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                    04-23-2025, 05:50 AM
                  • nev1001
                    What zener diode might fix the sound on Maestro Mayhem gaming chair?
                    by nev1001
                    Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                    The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                    It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                    I think an issue could be a zener diode (or capacitor) which has shorted out.
                    The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                    04-17-2025, 05:09 PM
                  • redbaron1007
                    Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                    by redbaron1007
                    I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                    Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                    09-09-2025, 11:10 AM
                  • Vincenzo2
                    Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                    by Vincenzo2
                    My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                    Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                    I put some pictures here to show that it is labeled "M7"....
                    09-07-2023, 07:43 PM
