Samsung Syncmaster 220T - flickers.
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung Syncmaster 220T - flickers.
    There is another thread running on a T220HD - I have not looked yet to see if it is the same and cant remember tho I have had some input.***
    One question I never asked is have you tried it with a known working source connected
    and when the backlight goes out what does the power led do.
    And can you see a very dark image after the backlight has gone out of what the PC is outputting - perhaps shining a flashlight on the screen from different angles.
    Have you tried vga and dvi - I have read a few problems have been with the aito select
    going wrong and it not being able to decide what the source is - digital or analog.
    EDIT*** No totally different machine its a TV
    • carbonfiber
      • Dec 2012
      • 49
      • Israel
      the video source is good. i am using DVI port. earlier i tried VGA also - same same.
      unfortunately i cannot continue today.
      tomorrow I think i will try replacing other caps i didn't have replacements for.
      selldoor, thank you very much so far, i will be back to report!
      • carbonfiber
        • Dec 2012
        • 49
        • Israel
        Hi (again)
        I have replaced almost all the caps on the PS and things are much much better now, BUT still i have seen it restart at least once, though it is much more stable now.
        The capacitors that i haven't changed are the little ones 10uf 50v cap and the one above.
        just wanted to ask, can those little guys cause big trouble? what are their role?
        Thanks !!
        • carbonfiber
          • Dec 2012
          • 49
          • Israel
          Hey,
          i need help please.
          i want to order a new power supply for this monitor.
          My board model is PWI2004SP(J).
          The board i can find availible is PWI2004SP(G).
          http://www.ebay.com/itm/Power-Board-...item27bd3e9041
          are the compatible? can i buy PWI2004SP(G) and it will work?
          they look identical.
          Thanks in advance.
          • the_raver514
            • Mar 2013
            • 5
            • canada
            got the same problem. board seems flawless but cant get picture on my T220
            • the_raver514
              • Mar 2013
              • 5
              • canada
              #26
              yes it will fit since it is the same specs actually
              • Rick_1234
                LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                by Rick_1234
                Good evening, gentlemen.
                I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                https://drive.google.com/file/d/1L6S...ew?usp=sharing
                Things I tried
                - Bought a new AC adapter thinking that was the problem but the problem...
                06-22-2024, 04:44 PM
                09-07-2024, 05:50 AM
                by momaka
                03-15-2023, 10:17 PM
                09-06-2024, 11:40 PM
