Samsung 940n wont turn on
  • selldoor
    Slow Learner
    • 7870
    #41
    Re: Samsung 940n wont turn on
    Hmm - there are actually 9 pins on both and 9 wires and he has 0v on the end for the one he has 5.3v on.
    Please can you Test them again and just list the voltages for us. on each connector.
    • CroTech
      Student
      • Dec 2012
      • 149
      • Croatia
      #42
      true... I dont know why I did the readings of 7 pins when there is 9
      Diods readings:
      D604 - 810 red on the line 168 with black on the line
      D605 - 808 red on the line 167 with black on the line
      That says they are faulty, but I had tons of those before and they checked out good when I desolder it from the board and retest. Will check that in the morning... It would be nice if those are the problem.
      PIN1 0V
      PIN2 4,98V
      PIN3 0V
      PIN4 0V
      PIN5 0V
      PIN6 1,68V
      PIN7 1,68V
      PIN8 0V
      PIN9 0,01V
      And a weird thing happend... I accidentaly shorted two pins I think maybe 5 and 6... Checking again for readings and woila 14,8V on pin2 pluged in the logic board and it had a LED on, but didnt connect the screen. What now?
      • Rtech
        • Jul 2010
        • 1095
        #43
        Checking the diodes is better if you use the diode test facility on your meter,if you have one ???,and that would show the voltage drop when going from pos to neg,and OL(or1)the other way around.
        Its getting late,and need to go back now and see where we are.
        Is there anything on the connector which tells you what each pin is supposed to have on it,or any letters like GND,On?off etc ??/
        • selldoor
          Slow Learner
          • 7870
          #44
          Extremely odd - I had thought we were only looking for 5v on pin 2 or 1 as you originally thought and that seemed to tie up with the marking on the board. This is why clear pictures are a must - I wa s reading the 14.5v as 5v because I couldnt see the 14. but looking again and brightening my screen I see it. BUT I dont see 5v on pins
          6 and 7.
          What now _ Im not sure have you got a voltage on 6 and 7.
          Perhaps when you switch it off it will revert to the fault at some point you will have to switch it off and back on as its no good hoping it will keep the 14.5v
          Rtech - they are on the board but the pic is so bad I misread them
          1 is Bd ??
          2 is 14.5v
          345 gnd
          67 5.1v
          8 AD-??
          9 On-Off
          • CroTech
            Student
            • Dec 2012
            • 149
            • Croatia
            #45
            I dont think i have that on my meter... Can u check it? there is a picture of it on the first page of the thread...
            The board has written
            1 :BDM
            2 : 14,5
            3,4,5 : GND
            6,7 : 5,1V
            8 : ADM
            9 : ON/OFF
            • CroTech
              Student
              • Dec 2012
              • 149
              • Croatia
              #46
              Now I see what I did... When I was taking the readings of the pins I skipped pin1 and pin 9 (probably cause they are far away in the connector). But as I can see the readings are still the same. And still I cant figure out how I managed to get 14,5V and LED ON with shorting the pins. Tried shorting 5 and 6, 6 and 7, still nothing.
              • Rtech
                • Jul 2010
                • 1095
                #47
                Well that changes everything perhaps !! because you have not got 5.1 v on pins 6 and 7,nor 14.5v on pin 2,so you need to check the voltages again,with the power supply ONLY plugged in..and then with the logic board plugged in,and we start again.
                Have not checked the meter yet.
                • Rtech
                  • Jul 2010
                  • 1095
                  #48
                  On the meter it MAY be the one with the red outline at about 25 minutes past the hour if it was a clock !!
                  On second thoughts its not,I think that gives an audible BLEEP to show a sort cct,,,testing fuses for instance.
                  • Rtech
                    • Jul 2010
                    • 1095
                    #49
                    On second thoughts may be not, probably gives an audible Bleep, to indicate a short cct,, for testing fuses etc.
                    • CroTech
                      Student
                      • Dec 2012
                      • 149
                      • Croatia
                      #50
                      I used this and I assume thats what u are refering too. I always used to check diods with that function.
                      Readings without the logic board:
                      PIN1 0V
                      PIN2 4,98V
                      PIN3 0V
                      PIN4 0V
                      PIN5 0V
                      PIN6 1,68V
                      PIN7 1,68V
                      PIN8 0V
                      PIN9 0,01V
                      Readings with the logic board:
                      PIN1 1,4V
                      PIN2 5,3V
                      PIN3 0V
                      PIN4 0V
                      PIN5 0V
                      PIN6 1,65V
                      PIN7 1,65V
                      PIN8 0,04V
                      PIN9 0,04V
                      • Rtech
                        • Jul 2010
                        • 1095
                        #51
                        So Diode testing off the board,for those 2 are a must next.
                        • CroTech
                          Student
                          • Dec 2012
                          • 149
                          • Croatia
                          #52
                          Will check them in the morning after a cup of coffee... Thanks for the help guys, and I apologize for my mistake with the pins readings.
                          • Rtech
                            • Jul 2010
                            • 1095
                            #53
                            No apology necessary, both Selldoor and myself,have probably made lots,when we were just starting....and still do...
                            • CroTech
                              Student
                              • Dec 2012
                              • 149
                              • Croatia
                              #54
                              Diod testing mode:
                              One has 189 and the other has 180, both of them have no readings when I change the probes...
                              Ohms:
                              When using Ohmmeter one has 192 Ohm, the other 190 Ohm and when probes are switched, no reading...
                              I thnk that when using a diod mode, the readnigs should be from 300 to 750 for a proper diod. Correct me if I am wrong.
                              • Rtech
                                • Jul 2010
                                • 1095
                                #55
                                Assuming that you changed to a much higher resistance range when you get no reading ??
                                The diode readings look ok,these are fast recovery diodes.
                                • Rtech
                                  • Jul 2010
                                  • 1095
                                  #56
                                  The 2 caps near the connector are suspect now.Also I note D606 on the heatsink !!Has this got 2 legs or 3 ?? what is the part code on it ??also on the back of that heatsink is a blue cap which looks like it has a 'hole'on the top !! or is that just the photo angle ??
                                  • CroTech
                                    Student
                                    • Dec 2012
                                    • 149
                                    • Croatia
                                    #57
                                    When I set my multimeter to 2000kOhms it says 98 in one direction, 58 in other direction.
                                    The other one says 114 one direction, 68 the other direction...
                                    That´s weird? I assume the multimeter is not precise when put on 2000k.
                                    • CroTech
                                      Student
                                      • Dec 2012
                                      • 149
                                      • Croatia
                                      #58
                                      D606 has three legs and part number is EN210A 7525EN...
                                      I dont own a capacitor meter to check the capacitor.
                                      • Rtech
                                        • Jul 2010
                                        • 1095
                                        #59
                                        The 'forward' resistance is naturally low,so the 2000K range readings seem to be wrong for some reason.
                                        • CroTech
                                          Student
                                          • Dec 2012
                                          • 149
                                          • Croatia
                                          #60
                                          I can double check it... I can even make a video
                                          D606 s a double diode in one housing... Like a transistor
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            09-06-2024, 06:20 PM
