I-INC iF281D 2STB
  • BCPPLS
    • Nov 2012
    I-INC iF281D 2STB
    I fear my monitor is going to die soon.
    I found this thread after searching for support on my 28" monitor; I-INC iF281D which every morning displays a few seconds then black, then flashes back on for a fraction of a second until I turn the monitor off count to 10 turn it back on and it generally works. Sometimes it takes a second turn off to work correctly. It'll work all day long then; next morning the same happens. I have no clue what's wrong but found a nice thread which leads me to believe one day it'll just stop coming back to life/bright. Please move if in the wrong place. I'll check back in a day or two to see if this was moved or replied to.
  • FIXITNOW
    • Jun 2008
    • 128
    Re: I-INC iF281D 2STB
    it will proberly be bad caps crack it open and see what power board is fitted
    • BCPPLS
      • Nov 2012
      I'm not surprised you said to open it up. I'm still finishing up the rush job's from the end of the year. By the end of this week I should be done. Then I'll open it up, & can go back to my old monitor if I break it.
        by momaka
        03-15-2023, 10:17 PM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
      • sew333
        Pc shutdown, monitor flickered with no signal after 10 seconds
        by sew333
        My pc:
        10850K stock 4800mhz stock Kraken X73 good temps
        2x16 GB DDR4 GSKILL 3000mhz XMP
        Seasonic Tx-850 Ultra Titanium
        Gigabyte Rtx 3090 Gaming OC
        Aorus Z490 Pro Gaming
        1 TB SSD
        4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
        Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
        Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
        Power...
        02-22-2022, 10:27 AM
        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
        I am comparing them to a brand new one that I installed
        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
        I going to let it run for several days before I remount back on the wall next to the...
        09-05-2024, 06:48 PM
