HP 2509M Monitor - no display
  • jetadm123
    • 2169
    Re: HP 2509M Monitor - no display
    ccflwarehouse.com also carries a complete line of parts.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      They also have "Bargains" if you hit lucky on ebay - this is an example.
      Company is Plazmo Industries
      http://www.ebay.com/itm/BLOW-OUT-SAL...item3caff167a4
      • northpoint
        • Dec 2012
        • 41
        Ok, I have decided to replace the broken tube and resurect this poor hp monitor. The tubes are 569.9125mm from glass end to glass end. As best as I can tell the diameter is 3mm. I dont think a direct replacement is available as I dont see anything near 569/570mm in length for a tube.
        At ccflwarehouse closest I get and not overshooting is 535mm. This would leave 3/4 inch short on each side.
        They show a diameter of 2.6 with a length of 565. Now thats only 4mm short. Is the diameter going to make that much difference in brightness or whatever?
        I would hate to think I have to have these custom made. I have never ordered tubes before so I lack the experience in replacing them. Any help is appreciated here.
        • jetadm123
          • 2169
          I think that your questions would be better answered by ccflwarehouse. Other members have reported they are very helpful and are better qualified at answering your questions.
          • jayoung
            • May 2011
            • 172
            I have used the following e-Bay auction and in the payment, put the information that they request and list the actual LENGTH and DIAMETER of the ccfl that you want to replace (3.0mm x 570mm). I usually order 2, just in case I break one (I haven't yet) because the shipping for the second one is free. $13 for 1 ccfl and $21 for 2.
            http://www.ebay.com/itm/New-High-Qua...item3a51786c85
            • northpoint
              • Dec 2012
              • 41
              Thank you for the ccfl tube recommendation. Im going to get something ordered up today. Need to get this monitor completed.
              I certainly understand ordering 2 tubes. Im sure it was I that broke the tube in this monitor by accident. Really got upset and had to leave the shop for awhile to cool off
              Saw one of these 2509m monitors for sale on ebay for parts. They were asking around 65 bucks for it. Because of the size I was thinking this would be a shipping nightmare.?
              Thanks again,
              Northpoint
              • northpoint
                • Dec 2012
                • 41
                Ordered in two 2.6mm x 565mm tubes and 8 endcaps. In talking to them its more important to get as close to the diameter of the tube then the size. I have also read to try and stay about 5mm within the size of the tube but not going over the original size.
                As soon as I can get these (nebraska ---> Indiana) from ccflwharehouse.com I can finish the repair and be done with it.
                Thanks again for all the advice from everyone. This certainly made a great beginner project for repairing monitors. Since the monitor is somewhat expensive it was worth the money. I see they sell for about 225.oo or so.
                Northpoint
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  ccflwarehouse.com also sells them pre-harnessed in addition to bare lamps. Pre-harnessed is more expensive, but easier to install.
                  --- begin sig file ---
                  --- end sig file ---
                  • Canadianllama
                    • Aug 2013
                    Did you ever get this working? i have one, but don't wont to spend the time and money if it never got working, i see this is a hugely common issue with these monitors.
                    • northpoint
                      • Dec 2012
                      • 41
                      I was able to repair the power board but buying and trying to install the tubes was a bear. I learned that its best to just send the tubes in and have a place do it for you.
                      The monitor is not working as I couldnt find the right length tubes to put in it. So, I do have a working screen (minus the tubes), working power board and such.
                      I think that you can get it working but send in the light tubes plus assemblies and have a company do the repair on them so you can get them back and just install them.
                      Best of luck,
                      Northpoint
                      • kris760
                        • Sep 2013
                        My screen no longer has power as of today. I took it apart which was a pain. Tested the mosfet. It test bad. FDB6030L Im trying to find this part where did you buy it at? Also whats the part number on the diode you changed.
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                          by momaka
                          03-15-2023, 10:17 PM
                        • penangit
                          Hp v193 monitor power supply board
                          by penangit
                          Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                          I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                          I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                          Steps taken so far:
                          Checked all...
                          02-21-2023, 04:00 AM
                        • prodigy83
                          MacBook Pro M1 Pro Logic Board 820-02100 Mosfet where to purchase?
                          by prodigy83
                          My reference only: TT10141.
                          Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
                          Mosfet specs are as follows:
                          Chip markings:...
                          03-12-2024, 01:38 PM
                        • tofik
                          MOSFET equivalent K8A60DA
                          by tofik
                          Hello guys,
                          I have a shorted MOSFET K8A60DA with the following characteristics:
                          Type Designator: TK8A60DA
                          Marking Code: K8A60DA
                          Type of Transistor: MOSFET
                          Type of Control Channel: N -Channel
                          Maximum Power Dissipation (Pd): 45 W
                          Maximum Drain-Source Voltage |Vds|: 600 V
                          Maximum Gate-Source Voltage |Vgs|: 30 V
                          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                          Maximum Drain Current |Id|: 7.5 A
                          Maximum Junction Temperature (Tj): 150 °C
                          Total Gate Charge (Qg): 20 nC
                          Rise Time (tr): 25 nS
                          Drain-Source
                          07-19-2023, 05:18 AM
