Samsung 245B diagonal lines Problem
  • Falcon99
    • Mar 2011
    • 10
    Hello guys,
    i recently bought a Samsung 245B TFT display, that was offered as defective and without any function.
    When i opened it, i was surprised because all internal plugs connecting the boards had been disconnected. No wonder why nothing at all worked anymore.
    I measured RB805 which is one of the most well-known problems on this display. And well, mine was defective, too. I changed it, plugged all cables together and fired it up.
    Well it works again, but: There are diagonal lines going from down left to up right. They are best seen on white backgrounds. I tried to get them with a foto.
    It does not matter, if i change the resolution or the refresh rate - the lines can always be seen. I can also see them when windows is booting, so it should not be a driver problem. I think the only difference is that they become stronger and weaker sometimes.
    Does anyone have any idea what that could be? I consider recapping all the boards, but i have no idea, if that would bring a solution to my problem.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Samsung 245B diagonal lines Problem
    Hmm, If I stay at the screen too long, I can see those.
    But, I suspect it could be some ripple somewhere...
    Have you found any bulged capacitors?
    Muh-soggy-knee
    • Falcon99
      • Mar 2011
      • 10
      No bulged caps yet, but from my experience they could be dead though... I think i will have a further look at them.
      • Falki
        Colorful LCD Vertical Lines on Samsung ue55es8090
        by Falki
        Hello there, ive recently found an older 55inch Samsung SmartTV.
        Sadly it has vertical lines at the left and one line in the middle-right.
        I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
        I have factory resetted the TV as well but also with no luck.
        I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
        A similar issue has been posted as well but also with no actual response ...
        08-12-2025, 04:19 AM
      • howardc64
        Samsung UN55JU650DF network/streaming problem
        by howardc64
        Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
        This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
        07-09-2025, 12:44 PM
      • Chrissygizmo
        Sony KD-55XG9505 lines on screen problem
        by Chrissygizmo
        Hello again everyone,
        This is my latest mission, to try getting this Sony tv back to normal working order…
        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
        02-19-2025, 11:31 AM
      • Dave03
        Samsung qe50q60Tau t con problem
        by Dave03
        Hi everyone so sorry my bad english Im hungarian
        so I have a few samsung qe50q60tau and I trying to repair t con problem, I have a 100% working main board 100% working psu for the tv for another tv I replace them boards for the wrong tv and the problem was same so the problem not the main board and not the psu, the back light is working
        I turn on the tv the qled logo is blinking turn on and off the tv I tried to tape the t con cable and I found the right pin for the tv is stable turned on but no picture, no qled picture only back light and not arrive the currrent for the t con board...
        02-06-2024, 03:05 AM
      • THXFX
        samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
        by THXFX
        Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
        I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
        When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
        What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
        I check capacitors and diodes and didn't find any short IN MAINBOARD.
        Measured all power supply...
        03-20-2024, 03:21 AM
