Envision G218A1: Indicator LED Turns off then on
  • abc617
    • Dec 2012
    • 3
    Hello, I've got this G218A1 monitor and I think there is something wrong with the inverter power board.
    What happens now is that it will turn on, screen stays black and the blue LED. Then after about 5 seconds, the blue LED turn off and kind of cycle through it. For clarity I've added a GIF i've made of my problem:
    http://s14.postimage.org/ssxda2fb3/image.gif
    Please ignore my lack of keeping a steady hand and the camera focusing, its my smartphone's camera.
    I've also included fairly high res pictures of my monitor's power board. My specific board is the one found at this online store: http://www.shopjimmy.com/envision-62...t-inverter.htm.
    PICTURE 1
    PICTURE 2
    PICTURE 3
    PICTURE 4
    PICTURE 5
    PICTURE 6
    PICTURE 7
    So my question is what should I specifically check for. I've tried following the 2 second sticky posted, but none of my results correspond to the results I should be getting if a diode or transformer or fuse is working. Nor what I should be looking for (since I'm guessing its a different model than mine).
    Any help would be greatly appreciated!
  • selldoor
    Slow Learner
    • 7870
    Re: Envision G218A1: Indicator LED Turns off then on
    Ok Some of the pics are ok however we do ask that they are posted on site
    please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attachm...1&d=1290283049
    https://www.badcaps.net/forum/attachm...7&d=1280167246
    "none of my results correspond to the results I should be getting if a diode or transformer or fuse is working"
    If none are correct it may be that your meter is not working or you are using the wrong settings. I think you may have to start over as you have not posted any results of your tests.
    This board has been worked on - do you have the history?
    Starter test for your meter put on ohms 200 setting and hold the probes together
    what do you get. Meter on VDC 20 measure a 1.5v battery and a 9 volt battery what do you get
    Did you have a source plugged in when taking the gif
    • abc617
      • Dec 2012
      • 3
      I took some new pictures and resized them to fit the attachment limitations. And for some reason the option to edit my original post is not available. But the GIF is too large to be an attachment anyways.
      As for measurements, the multimeter I was using was working perfectly fine, tested it on some regular 1.5 volt batteries and they were reading the voltage perfectly fine and tested it on a a couple of resistors I had and it read that fine.
      What I meant when I said that the measurements I took didn't match the results from the info from https://www.badcaps.net/forum/showthread.php?t=10419 was that the diodes and transformer measurements.
      When I measured some of the diode resistances, i had readings on both ends. Which is odd considering how a diode works (~infinite resistance from the cathode-anode). Diode test on the multimeter checked out though.
      And when I measured the transformer, after trying every combination of of the transformer pins, I didn't get resistances similar to what the post mentioned. I may have to re-measure it but they weren't close to the 950 ohms the post said I should be getting.
      As for some of the bad solders on the back, the original problem was that there was some horizontal line tearing with the monitor. It was a capacitor problem most likely so I replaced all of the larger caps. However this turning on/turning off problem happened BEFORE I resoldered the caps. I accidentally hit the back of the monitor and then the monitor went from functioning but had horizontal tearing to this turning on/turning off problem. I just decided to replace the caps to perhaps take care of the tearing issue and then try to figure out what was wrong power. I plan on resoldering the caps when I am able to get a free moment (school -> finals weeks).
      • selldoor
        Slow Learner
        • 7870
        Better start again then - do you think it would be better to leave this until your exams are over?
        What is the part number on the inverter transformers
        • ItepK
          LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
          by ItepK
          Hello everyone! I've found this television, and I began troubleshooting it.
          First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
          I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
          After the recapping, all the voltages stableized, however, the issue in the title still remains.
          I could...
          01-03-2025, 09:01 AM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • burbutsalos
          55" QLED QE55Q60T Turns on after 1 minute the picture goes bad and get in boot loop
          by burbutsalos
          Hello ,
          The issue with this set is that it turn on just fine and after a minute or so the picture shows either vertical lines or turns half black and from that point on starts a boot loop.
          If a let the unit to cool down for a minute the same pattern starts again. i had exactly the same mainboard as a spare and replaced it but nothing changed.
          Any ideas what to check?...
          12-12-2023, 06:06 AM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
