Gateway FPD1976w 2 seconds and then black
  • olafsz
    • Dec 2012
    • 6
    • Mexico
    Hello friends, I have a monitor gateway that only turns on for two seconds but then goes black screen. Continuous power led in blue color. This monitor previously repaired but now that I get to my hands want to compose. My question is about the following capacitors of the power plate.
    C509
    C820
    C818
    C815
    C817
    C522
    I think they changed them and just want to know if they are good values that they put.
    C509 - 220uf 50V 105 c
    C820 - 47uf 25V 125 c
    C818 - 1000uf 25V 105 c
    C815 - 680uf 25V 105 c
    C817 - 470uf 50V 105 c
    C522 - 150uf 35V 105 c
    Since it is the first thing that I would change. If these values correct strutted, if I could guide where most follow is greatly appreciated.
    Thanks and greetings from Mexico.
    Excellent Post
  • Lumberjack777
    • 464
    Re: Gateway FPD1976w 2 seconds and then black
    Greetings to my friend south of the border. Those caps actually look like the originals because they are CapXon. Horrible quality. Most people would have replaced with decent capacitors.
    There is a man out here that wrote an excellent article on "2 seconds to black" and how to diagnose and locate the problem. His nick is "retiredcaps" and here's his writing on how to do that. https://www.badcaps.net/forum/showthread.php?t=10419
    • retiredcaps
      • Apr 2010
      • 9271
      Start with post #19 as that is the latest version of the document.
      --- begin sig file ---
      --- end sig file ---
      • olafsz
        • Dec 2012
        • 6
        • Mexico
        Thank you for the information, only if they could help me with the exact capacitor values, since as I said, someone the change and not be if they are the real ones. I have no diagram or another monitor close.
        Thank you
        • selldoor
          Slow Learner
          • 7870
          There are at least 2 different power boards in this set -what is the board number.
          I would suggest you test the inverter transformers - a common failing.
          • jetadm123
            • 2169
            If you look at the ebay link, it looks like the repair kit for your board has the same value caps:
            http://www.ebay.com/itm/Repair-Kit-G...item35b0082bbe
            • olafsz
              • Dec 2012
              • 6
              • Mexico
              Thank you very much for the tip, if I have them right, then I'm for what follows. Thank you
              • olafsz
                • Dec 2012
                • 6
                • Mexico
                relocate the lamp cords and worked during more time approximately 5 minutes. I am thinking that the problem is the lamps and not investors. When the lamps are turned off it is impossible to see that the screen still continues to operate if it puts a front light.
                • selldoor
                  Slow Learner
                  • 7870
                  Does the power light stay on when the backlight goes off?
                  Post a good in focus picture of the back of the board
                    Acer Aspire A111-31-C509 Notebook 1 Specification for Upgrade or Repair
                    This specification for the Acer Aspire A111-31-C509 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A111-31-C509 boardview and A111-31-C509 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 11:39 AM
                  • zklgfs
                    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                    by zklgfs
                    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                    08-11-2025, 02:14 PM
                  • twonk9098
                    Lenovo Legion 5 high fan spin turns off after 34 seconds
                    by twonk9098
                    I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                    I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                    I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                    I have tried a few new bios but exactly...
                    07-14-2024, 11:19 AM
                  • liquidzorch
                    Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                    by liquidzorch
                    Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                    10-18-2024, 05:19 PM
                  • Rick_1234
                    LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                    by Rick_1234
                    Good evening, gentlemen.
                    I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                    To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                    https://drive.google.com/file/d/1L6S...ew?usp=sharing
                    Things I tried
                    - Bought a new AC adapter thinking that was the problem but the problem...
                    06-22-2024, 04:44 PM
