Another broken CTL, flashing LED
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    This one also won't power up, the LED on the front just flashes orange and blue. When plugged in it gives that high pitched whine sound. Getting 165.5V across the input cap, the voltage regulators are giving out proper voltage on the main board (going from right to left in the picture):
    Pin 1 = 0.00V
    Pin 2 = 3.31V
    Pin 3 = 5.10V
    Pin 1 = 0.00V
    Pin 2 = 1.80V
    Pin 3 = 5.10V
    Pin 1 = 0.00V
    Pin 2 = 3.30V
    Pin 3 = 4.78V (Seems pretty low)
    The whine on the power supply would change pitch when testing the regulators. Also, the fuses test fine. When unplugged the whine goes away immediately.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Another broken CTL, flashing LED
    1) For the future, when posting the results of the voltage regulator, add the part number so we can tell if the voltage regulators are good or not. We all don't have the eagle eyes of selldoor (although I was able to see enough in your photos to know all 3 are good).
    2) I always recommend hooking up a working computer to the lcd.
    3) What about the other voltages on the power board (i.e. the connector)?
    --- begin sig file ---
    --- end sig file ---
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Okay, sorry about that!
      On the cable going from the power board, 5VSB = 5.10V, 3.37V on the red wire, 0.02V on the orange wire, all the others read 0.00V
      Is it likely that the whine is one of the caps? They're all crap brands: Elite & Lelon
      • retiredcaps
        • Apr 2010
        • 9271
        1) Is there a legend (check backside too) that says what the different colors are?
        2) If not, red might be PS_ON (3.3V DC)? If yes, then there is a problem on the power supply because the inverter voltages are missing.
        3) I count 4 diodes in the secondary and 2 in the inverter section. See if the 6 are shorted or not.
        4) The whining could be from capacitors. My HP 22 inch had bad caps and one of them whined.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          I can check to see if there is a legend on the back. Am I checking the diodes for resistance or DC voltage? I might replace the Lelon start up cap to see if it goes away
          • retiredcaps
            • Apr 2010
            • 9271
            Use diode check on your multimeter. You should have 2 readings for each diode.
            • STKR123
              Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
              by STKR123
              As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
              I wonder if re-flashing the BIOS might be of any use here.
              As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
              There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
              11-03-2024, 06:58 AM
            • learnmore
              Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
              by learnmore
              Hello Community!
              CASE DETAILS
              Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
              13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
              Tried inserting firmware on USB and left it in for a few hours, but no change
              03-03-2024, 09:49 AM
            • chth96
              Is it possible bridging tiny broken trace
              by chth96
              When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
              cutting tiny trace.
              This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
              Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
              But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
              12-03-2022, 11:32 PM
            • Gjackson
              ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
              by Gjackson
              Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
              01-13-2024, 10:34 AM
            • burntonnerings
              Pioneer VSX-1021 MCACC flashing, can't find problem
              by burntonnerings
              Have a Pioneer VSX-1021 that goes to MCACC flashing as soon as it is plugged in.
              If I enter release mode, it powers on, the screen display is correct, but then it shuts down and goes back to MCACC after a few seconds. I can shut it down to standby (w/o flashing MCACC if I hit the power button as soon as release mode finishes the boot sequence).
              Entering reset mode and executing a reset doesn't change this.
              I am unable to enter service mode to see the error counts - Enter + Power button doesn't do anything, whether from normal standby or from MCACC flashing....
              12-09-2023, 10:11 PM
