viewsonic vx2255wmb-2 2 seconds to black
  • pookie21
    • Oct 2012
    • 11
    • australia
    Hi to all you great people on this forum.
    Firstly i turn on monitor and it flashes image then goes to orange.Did not try flashlight trick at this stage.Disassembled monitor and had visual inspection.I noticed high voltage ceramic caps c506 and c523 are burnt and have turned green(should be blue)and all caps looked ok. I ignored this and replaced caps X12 except 150/420v.
    Reassembled and whilst connected to my pc turned on and now screen flashes but this time blue light remains constant.Yes i can see image with flashlight.Well i thought i had achieved something ?. Got monitor apart again now and am trying to identify parts and learn how to test.Firstly the 150/420v capacitor reads 137.7 capacitance is this acceptable ?. Cannot get one yet from parts store.Secondly the two high voltage ceramic caps c506 and c523 which i have removed give me no reading no matter what i try with multimeter? .The markings on ceramic are both 10p3kv.It is my first attempt at this so would appreciate any help from here.Have attached photo (same as) but not my photo .In the meantime i am reading through forum to get any knowledge that will help me. Max [email]sangwa2001@yahoo.com[
    Re: viewsonic vx2255wmb-2 2 seconds to black
    Those are ballast caps for the lamps, very low capacitance, you need to check and see if it has any leakage resistance at all, your meter should show OL at the highest Ohm setting.
    Do they all have 10p3kv printing on them?
    It is 10pf 3000V, if it has resistance leakage, then the lamps will draw too much current which will cause the inverter to shutdown to protect itself.
    When these caps start leaking, they will get hot and the body will have light brown color:
    http://s807.photobucket.com/albums/y...nt%20FLX-3210/
    Replacement cap:
    http://www.mouser.com/ProductDetail/...ABWWD1BTwl8p83
    These Viewsonic VX series have a lot of bad caps problem just like any other brand as you can see here.
    http://s807.photobucket.com/albums/y...udm/VIEWSONIC/
    The 150uf 420V, how good is the cap meter? can it also read ESR? You may want to replace it. If you have meter with TRUE R.M.S reading, then set to AC and read the AC ripple on that 150uF cap, it should be 1~2VAC or less.
    • pookie21
      • Oct 2012
      • 11
      • australia
      Thanks Budm for the quick reply.Have a Digitech qm1496 and all known good caps i check are within capacitance stated on caps.No sorry do not have esr meter. With the exception of the 150/420v which gives me 137.7 everytime. Do i test ballast caps off board? I have the repair manual and schematics but still trying to get my head round the info.
      I will wait for reply before i unsolder ballast caps for testing.
      thank you very much.Max
        Yes, test those ballast caps off the board, if you have doubt about them, I would replace them since they can cause damage to the inverter transformers. Your meter does not put out high enough voltage for really find out if the caps are bad for sure, but if you can read resistance with you meter which can only put out less than 10V, just think what will happen when those caps are exposed to 2000V in the circuits.
        • pookie21
          • Oct 2012
          • 11
          • australia
          Thanks again budm, my friend can locate the parts in question and i will replace them anyway.I will also do the tests you told me.I will let you know the results.
          • pookie21
            • Oct 2012
            • 11
            • australia
            Hi budm, just went to my local store and they only have 10nf3k .Mine are 10pf3k could i use them temporarily to see if any result.
              That is too much capacitance, it will let the lamps draw more current than they should, so the inverter may go into shut down.
              10nF = 0.01uf
              10pF = 0.00001uF
              So that cap is 1000 time higher value than the original!
              • pookie21
                • Oct 2012
                • 11
                • australia
                Thank you budm. Will wait to get correct values. Bit annoyed that the salesman said yea they'll be ok mate. Max
                  ASUS Chromebook C523 Chromebook Specification for Upgrade or Repair
                  This specification for the ASUS Chromebook C523 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C523 boardview and C523 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS Chromebook...
                  09-06-2024, 11:40 PM
                • zklgfs
                  Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                  by zklgfs
                  I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                  08-11-2025, 02:14 PM
                • twonk9098
                  Lenovo Legion 5 high fan spin turns off after 34 seconds
                  by twonk9098
                  I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                  I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                  I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                  I have tried a few new bios but exactly...
                  07-14-2024, 11:19 AM
                • liquidzorch
                  Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                  by liquidzorch
                  Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                  10-18-2024, 05:19 PM
                • Rick_1234
                  LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                  by Rick_1234
                  Good evening, gentlemen.
                  I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                  To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                  https://drive.google.com/file/d/1L6S...ew?usp=sharing
                  Things I tried
                  - Bought a new AC adapter thinking that was the problem but the problem...
                  06-22-2024, 04:44 PM
