Newbie with Viewsonic VX2835WM Problem
    Hi All,
    I just wanted to introduce myself and highlight my problem.
    I bought my vx2835 about 5 years ago and it has provided me with a trouble free life until the past few months.
    I noticed that it wouldn't power up (no led lights) from start up and i would have to unplug the cable and plug it into a different socket to get it to turn on. It has been doing this intermittently for the past 2 months or so. However 2 days ago it wouldn't power on at all and there was a slight white flicker coming from the screen, i really thought that was it. I tried different sockets and cables but nothing.
    I then started hunting the internet for some ideas and i came across this forum. This has now given me some hope! I admit i am a bit ham fisted when it comes to soldering but i am not adverse to learning new techniques and skills and i hope with the help of you guys i can get this puppy up and running again.
    First thing i will do is take it apart and take photos of the boards/capacitors and upload for you folks to take a look at. I of course i will welcome your advice and knowledge as i have a lot to learn here.
    Looking forward to the challenge!
    Cheers
    Re: Newbie with Viewsonic VX2835WM Problem
    Hi, welcome to the forums.
    Everything you say sounds good, easiest place to start from is by opening it up and post some clear pictures of the boards.
    When you're ready, click on "Go Advanced" and use the "Attach pictures" function you'll see there to attach pictures here, and then we'll see what can be done about that monitor.
      Hi Guys,
      Well i managed to take apart the monitor without any breakages and went about photographing the appropriate parts today when i had some good light.
      I uploaded 8 photos, which i hope isn't over kill, i just want you guys to get a good look at what i am seeing.
      The first thing i noticed (and i am a novice at this) was the distinct discolouration on the power board and the definite areas that looked burnt - black/brown with some sort of residue there. When you held it up it also smelt pretty burnt as well.
      It looks, from what i have read on the other posts, that this power board has been running very hot (same as the Hanns G) during its life and has essentially burnt out - capacitors/circuits?
      So what i am trying to establish with the help of the forum is whether it looks, from my pictures, that it could be saved or whether it really is set for disposal.
      If you need more specific area photos please let me know.
      Thanks in advance to the folks who can chime in with some help here.
      Cheers
        Originally posted by scotstrength View Post
        Hi Guys,
        Cheers
        Never overkill when it comes to photos, since it's the only thing that forum members have that they can use to help diagnose the problem. Looks like they used some quality caps like Chemicon KY series, which is probably why you got 5 years out of it. They also used some low quality Lelon caps.
        Looking at your photos, there seem to be some bulged caps on the logic board: C198,C124 and C126. If you do a search on this site for VX2835Wm, you'll find these caps have caused problems for others.
          The power board looks OK, yes, it's a bit dark but that's in places expected to be hotter, like the transformers.
          The capacitors are a good brand and a good series, so I don't think they're a problem.. though it wouldn't hurt to check them if you have some way to do it.
          The video board on the other hand... it looks to me that at least the two capacitors by the linear voltage regulator are looking swollen.
          I'm thinking of C124 and C126 ... that chip between them is a linear voltage regulator.
          Its purpose is probably to convert whatever comes from the power board from to 5v , or it converts 5v from the power supply down to 3.3v
          If you have a multimeter, put it on Voltage DC.
          With all the boards connected and monitor turned on, put the black probe on the ground (one of the rings on the corners) and then put the red probe on the pins and the tab.
          Measure the voltages on all those pins and see if the output is 5v, 3.3v or 1.8v
          There's another capacitor that looks bad, c198.
          You might also want to check C176 , near another linear regulator U33 - check the voltage on the pins of that regulator, it's probably for 1.8v
          There's another linear regulator U41 ... check the capacitors around it and the voltages on the regulator.
            Hi Guys,
            Thanks for taking the time to look at my pics, i can't believe you think it could be a candidate for saving, i really thought it was done.
            I am off to buy a multimeter today so i can test the board and some test circuit boards to practice my soldering.
            I have to admit i have never tested anything electrical so i am a complete novice as far as how i go about it.
            If anyone gets the chance i have included two links below of multimeters that are at my local electrical shop - note the ones which have the letters PR highlighted in green are in stock at my local shop - and i was hoping someone could have a look and give me a rough idea of what is required for testing boards and let me know which one would be suitable.
            http://www.ges.cz/en/measuring-instr...ing/SEA2G.html
            http://www.ges.cz/en/measuring-instr...ing/SEA2H.html
            Additionally are there any stickies on 'testing' within the forum? A sort of idiots guide on not getting blown up or making matters worse!
            I had a look on the various threads but couldn't find anything for the novice.
            Thanks again
              For basic tests, any multimeter would work.
              A good and cheap one from that page would be this one: http://www.ges.cz/en/digitalni-multi...S07313196.html
              A slightly better one would be this: http://www.ges.cz/en/digitalni-multi...S07313190.html
              It adds measuring capacity but in real world, that's not very useful, as capacitors often go bad without capacity value changing enough to tell you anything. So the first meter would be enough for you.
              Even if you don't fix this monitor, a multimeter is always good to have around the house, so you won't feel sorry.
              How you do measurements with a tool like this...
              It comes with two probes. You plug the black one in the COM (short for common, as it's common probe for all measurements) and the red one in one of the jacks, depending what you want to measure.
              For example, if you want to measure DC voltage - that's DC with a line and dots, AC voltage is the wiggly line with AC by it - you plug the red probe in the jack marked V omega Hz C . As you can probably tell, this jack is also for measuring resistance (omega sign) , frequency (Hz) or temperature (C)
              Now you have the probes plugged in and you want to measure... in our case, you expect the voltages to be 12v, 5v, 3.3v, small values.
              So with the probes away from the boards, you turn around that switch until it's positioned on DC voltage section (the one marked with DC and line and dots under it) and a value that's above what you expect to be there. If you expect 12v, you select 20v.
              If it turns out to be more than 20v, the meter will show OL (from overload) or not show anything, and you should remove the probes in a few seconds otherwise it may not like it and if it's a bad meter it may damage itself. You just have to switch to a bigger value in that case.
                Thanks for the tips Mariushm,
                I didn't see your post before i went shopping but ended up buying the second one you recommended so i guess great minds think alike!
                This is a slow work in progress as you can tell with my infrequent posting but i hope to be able to get some testing done this week.
                After another careful look at the board and some additional capacitor reading i noticed i have at least 4 caps with mushroomed tops which will need to be replaced on the main board and possibly one on the power board. Of course testing should tell me more.
                If i am having problems i know where to come and i will report back in once i have some results.
                Quick question though,
                What are the main things i should be careful of when testing the main board to make sure i don't do more damage to the circuitry?
                Thanks again.
                  Just be careful not to accidentally touch the HOT side (the high voltage area) and kill yourself..
                  Always keep the power supply isolated, some heatsinks may be live (high voltage) so you don't want to just flip it over and have it stand on the metal frame or the panel - I tend to use a cardboard or several sheets of A4 paper sheets covering the surface I work... both are insulators
                  Even after you pull the power cable out, don't grab the power supply in your hands, the large capacitor will still hold a charge... so you really don't want to touch both its pins on the back side of the board with your palm or fingers. The capacitor will discharge to safe levels (usually, not a rule! measure dc voltage across it, should be safe when it's below about 20v DC) in about 3-5 minutes.
                  When measuring voltage on the hot side, put the black probe on the GROUND on that HOT side (for example one of those rings for the screws which hold the PCB in the metal frame)
                  When measuring voltages on the secondary, use the ground from that side... ex the ground on the connector going to the display board which is usually a black wire... or the negative side of a capacitor on the secondary ...
                  Select a value higher than the value you think it's gonna be in the circuit... the power supply says on it that it outputs 24v, 12v and 5v so set it to 200v and if it's below 20, switch to 20v for better accuracy.
                    I thought I recognized that board! That's the same one used in the Hanns-G 28". Due to the heat, that board tends to dry out the smaller capacitors in the middle. Try this: replace the 3 caps circled in red. And I would also replace the 5 circled in blue. See if that doesn't bring it back to life ~L-J-7~
                      Hi Guys,
                      Thanks for all your advice and tips so far and no i haven't blown myself up yet!
                      To be honest the past week or so i have been reading over various articles and looking at youtube clips on testing boards and i have to say i am still pretty clueless about the mechanics of it all.
                      How exactly do you set the dam thing up to test with your multimeter?
                      Please i know this may seem like a dumb question but i am really an electrical novice.
                      I have both the power board and main board out of the case and if i want to test various points how am i supposed to position the boards? The power board is normally grounded into the cover plate of the boards and i am little lost as to what surfaces i should be placing them on and where exactly i should placing my probes? So my questions are thus:
                      Should i be suspending both boards on top of little pieces of wood perhaps and have no part of the soldered joints on the bottom touching anything else?
                      Should i only be testing the voltage regulators that are around the capacitors - and is this to help me see whether it is the capacitors that are bad, where the voltage is being disrupted or something else i have missed completely?
                      As for placing the ground probe if/how/when i have the boards suspended/set up am i still grounding it on one of the corner rings or should i use something else?
                      I know the above may seem rudimentary but i failed to find out this basic info from the forums or youtube.
                      Yes i could i probably just replace all the caps and see what happens but seeing as i did buy the multimeter i would at least like to give it a go.
                      In addition what is the opinion of Hitano caps? I can pick these up easily enough at my local shop where as the Panasonic ones would have to be an internet order from Germany - no biggie but if Hitano will pass i could get these quicker.
                      Thanks again guys
                        I had the same problem that Scotstrenght had and my monitor went out completly. The C124 and C126 were both bad so I decided to replace them. 1.5 hours later after tear down and assembly again it came back up just like new. Screen was brighter than it's been for a long time it's like new again. So my problem was just the two caps. I've never replaced caps before but I'm a handy guy so it was already not working so said give it a go. Was so easy at least for me, I took my time on the board to make sure I didn't get it too hot or damage it. Went to Radio Shack to get the caps figured since the ones on the board only lasted for 5+ years that if I get a couple more years out of the fix it was worth the test. Replace with 470uf 35V caps since RS this not have the 16V on hand. Works like a charm so if I have to go back in a couple of years from now it's worth the cost.
                          If you have used readioshack caps you could be back in weeks not years.
                            That could be but this is my first time replacing caps. It went well and if I have to do it again then at least I know I can without a problem. Time will tell if they last and I do have a backup monitor on hand if it goes bad again. What would be the best caps to buy and have on hand just in case? Thanks for your input... They are 470uf 16V but I used 470uf 35V.
                              The best place to buy caps in the USA is from DigiKey. For price, fast shipping and low shipping cost; they can't be beat. Good quality caps are the Panasonic's. Most people in this forum recommend them the most. But I'll also use Rubycon, or Nichicon if the Panasonic cap is not available. Did you catch the temperature rating on the radio shack caps? Was it 85c? You want good low ESR caps (Panasonic,Rubycon,Nichicon) that are rated at ----> 105c <---- That's what'd I'd definitely use in the future.
                                hi all, i had the same problem with my viewsonic vx2835wm, and replaced 3 capacitors on the power board, it worked for more than two years, now i have a problem with white screen.,I have power but i only have a white screen, no picture. Please help, sorry for the English
                                  Your english is just fine. And welcome to badcaps
                                  With a white screen the first thing to check is to see if the cable that goes to the lcd panel is plugged in securely. I have seen them wiggle loose all on their own.
                                  The next thing to check is the main board. If you could post some pictures it would help a lot.
                                  Hopefully its just that cable wiggled loose.
                                    Issue with my ViewSonic VX2835 too - The blue light comes on and then turns yellow with the screen remaining black with no image.
                                    I have already replaced all capacitors across the power board and the video board. Advice please.
                                      Does the screen flash at all? can you post good clear pictures of your boards
                                      front and back?
                                        I am having the exact same issue as most people. My issues is I cannot get it disassembled. I have removed all of the screws. I have now sort of destroyed the casing trying to separate it.
                                        I even have found the factory manual and still I cannot figure out how it is held together.
                                        someone please share their trick?
