Acer AL1917 restarting
  • Behemot
    • 4845
    • CZ
    Re: Acer AL1917 restarting
    Tried CCFL from the other display, still restarting, seems that problem is in the inverter itself.
    Will ask friend of mine for camera, I left mine at home and as you see withotu camera it would be difficult to take pictures
    • Behemot
      • 4845
      • CZ
      Here are the images finaly, if you can advice comething from it, would be cool
      ATM, there are some caps recapped, some original as I tried if the problem is not in in too low ESR of replacements and so
      • Rtech
        • Jul 2010
        • 1095
        The two Mosfets fail regularly on DAC Boards,and thats probably the problem.
        • Behemot
          • 4845
          • CZ
          Those DIP-8 chips? They're actually the lately comon two-transistors-in-one-package? I haven't checked them, thought they are some drivers actually
          • Rtech
            • Jul 2010
            • 1095
            Chances are it is them.
            • Lumberjack777
              • 464
              #26
              These boards also have SMD fuses on the bottom. Check the one I circled in red, and any others you might find on the bottom.
              • selldoor
                Slow Learner
                • 7870
                #27
                You also need to remove that yellowing glue
                • Behemot
                  • 4845
                  • CZ
                  #28
                  Isn't it there like additional protection against high-voltage short? It is not any way burned to be conductive.
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    Id vote for them as well
                    See here
                    https://www.badcaps.net/forum/showpo...&postcount=204
                    has restarting problem also, but cant read what chips you have and you did not say.
                    • sabre504
                      • May 2010
                      • 449
                      • United Kingdom
                      #30
                      If memory serves they should be AOP605
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        You are right I thought it was white turned yellow - next step would be brown and conductive but it was never white on closer look it is a sort of semi see through lacquer. - sorry.
                        • Behemot
                          • 4845
                          • CZ
                          #32
                          Bot FETs as well as all fuses are fine.
                          • selldoor
                            Slow Learner
                            • 7870
                            #33
                            Originally posted by retiredcaps
                            Just curious, what voltages do you get across the
                            1) big filter cap? Is it stable?
                            2) little startup cap? Is it stable?
                            3) 5V SB?
                            when the problem happens?
                            Did you check these? I was trying to look for the startup cap but you have clipped the picture?
                            Can you try with it all connected up but with the ribbon cables to the lcd panel disconnected
                            • Behemot
                              • 4845
                              • CZ
                              #34
                              Have you even read the thread? It works fine without CCFLs connected. Tried backlight from another display, same behaviour.
                              Voltage accross input capacitor is good. Problems persist no matter what capacitors I use so here is not the problem, the original ones were not the soruce of the problem. Everything now leads me to bad inverter transformers.
                              ADD// I've replaced input cap with no change. If it helps anything, I hear strange buzzing for all the time, except when it turns off. It comes from the main transformer.
                              If I disconnect one of the CCFLs on the B/W cable side, the other flashes for a fraction of second, but it seems the whole power supply stays turned on. So can it be bad transformer after all? It may be some problem on primary when the rectifier and fuse were blown, right?
                              • Behemot
                                • 4845
                                • CZ
                                #35
                                I think I have found the problem. When changing one small capacitor, I have burned tiny path near to it. I have connected the cap to one joint of the path but didn't notice it was actually interconenction between two parts of some circuit. After joining it with piece of wire, it behaves more normally. Now I need to get some VGA cable to test it
                                ADD/ oh, here is one in a drawer
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #36
                                  Behemet - can you recall where the damaged trace was - perhaps mark it on a picture?
                                  There are a couple of threads with restarting problems so might be relevant.
                                  • Amraks
                                    • Nov 2011
                                    • 725
                                    I just realized what u was doing selldoor thanks.
                                    I hope it was the 220uf 50v cap trace.
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #38
                                      It's on the picture 4 of 5, bottom left corner with the SSOP-8 chip. You see there is the bad soldering with crystalized dump of solder, several centimeters north from the chip in them iddle between three SMD diodes? That's where I've burned the trace. As the problem was with el'cheapo PCB combined with my 125W soldering pistol, I think it is not usual actually
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        Thanks for that - just to be sure - you mean the area in the yellow box?
                                        Surprised with a 125W there wasnt a hole right through
                                        Amraks has a similar problem - destroyed the same trace - I think.
                                        • Amraks
                                          • Nov 2011
                                          • 725
                                          both sides are destroyed.
                                          so negative side.
                                          wondering were the negative side leads too.
                                            09-06-2024, 05:27 AM
                                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 05:00 AM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            Acer Swift SF314-43-R9W7 + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift SF314-43-R9W7 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-43-R9W7 + Pack Gold Acer 14'' boardview and SF314-43-R9W7 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-07-2024, 03:10 AM
