Gateway black screen
    replied
    Re: Gateway black screen
    Do you hear ticking from the transformer? Next thing to check will be the 2 8-pin MOSFETs in the inverter section to see if they are shorted or not, P/N?
  • davg
    replied
    Originally posted by Rtech
    So what tests have you done to this one with No Led etc ?? Voltage across large Capacitor ??,fuse checking ??
    As stated in my first post the voltages across the large cap is 165 volts the fuses are ok no voltage to the logis board and 56 volts at both sides of the start resistor voltage across the run cap is fluxating can't get a reading jumping from 5 to 11 volts
  • Rtech
    replied
    replied
    That is a big information.
  • davg
    replied
    Originally posted by retiredcaps
    1) If you can see the desktop image and the power LED is green, then your power supply is working fine. If the power LED is not on, then we need pictures of the main board.
    2) I would check U301 and U302 on the backside to see if they are shorted or not. Instructions are in my 2 seconds guide under the mosfets section.
    3) On the 10 pin connector to the mainboard, there is one pin labeled BL. This should be > 3V in order for the backlights (BL) to come on.
    4) Great clear focused pics.
    Sorry but this unite do not come on no led I was thinking of another unite and since I had this one dimantled I didn't check before posting. I do know that the unite will work with another board because I tried one. So my heading should have read Unite will not power on. Should I make a new post?
    replied
    Please check the voltages as shown.
  • jetadm123
    replied
    Also check the black square 3.15A fuse in the lower left of your board. Next to jumper wire JP202.
  • retiredcaps
    replied
  • jetadm123
    replied
    What is the voltage across the 47uf startup cap next to D105? Located within the heatsink with the single transistor mounted on it.
    Oops! Mis-read your first sentence. Disregard what I said and proceed to retiredcaps suggestion.
  • davg
    started a topic Gateway black screen
    This unite has black screen can see desktop with bright light but back lights are not starting. The ccfl are tested ok with another board. Caps have been replaced. Voltage checks reveal 165 dcv across the large cap o volts at all points to the logic board. 56 volts dc at both ends of the start resistor? I read a post somewhere by PlainBill that the voltage at the start resistor should read 170volts one end and 10-25 volts at the other end so is this a indication that this resistor is bad and can someone tell me the value of this resistor? This one is covered with heat shrink and I can't read it without taking it out.
    Sorry this unite does not power on, no led. My bad but was thinking of another unite however all other info is as posted
  • HTR-Informatique
    by HTR-Informatique
    02-09-2025, 06:51 AM
  • VcemPzd
    Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
    by VcemPzd
    Hello everyone !
    My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
    04-28-2025, 10:14 AM
  • DaniK
    Acer Aspire E5-574-52RH - black screen
    by DaniK
    I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
    Laptop came in for a SSD upgrade, took everything apart to install the SSD.
    Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
    Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
    The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
    Symptoms are:
    - random black screen after displaying Acer logo...
    02-21-2024, 06:27 AM
  • turmix
    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
    by turmix
    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
    During another reassembly, I made a mistake, and...
    01-29-2024, 03:48 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
