Neovo F-419 inverter transformer blown
+ More Options
Posts
  • LaurieY
    • Sep 2012
    • Spain
    I have a Neovo F419 in which one of the transformer secondaries is OC.
    The device is labelled
    DG100016500
    LSE1147A
    The schematic shows it as EEA-17 There are some EEA-17's on ebay one as EEA17-HC the other as EEA-17-AE. I can't find datasheets
    I see that others have had this (thread 240213). Any idea what difference between the two (-HC and -AE) I don't want to blow anything else.
    There are no dodgy looking capacitors but the 12V line is running at about 14.5V does this indicate a problem?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Neovo F-419 inverter transformer blown
    No.
    Most lcd power supplies are unregulated. Once a load (like the inverters turning on) is applied it will be closer to 12V.
    --- begin sig file ---
    --- end sig file ---
    • notallbad
      Sony Cmt-cp33md power transformer blown
      by notallbad
      Power transformer has open circuit on the 230v primary side, its tapped for 115v too which is also open so most likely the thermal fuse has blown. It doesnt look like it would be possible to open it up to check the thermal fuse so looking to replace.
      What are peoples thoughts on repair?
      replace the one transformer with 2
      replace like for like, though unlikely to find a direct replacement...
      01-22-2023, 03:47 PM
    • reessi
      Imac A1312 - Blown Diode, Need Inverter Schematic?
      by reessi
      iMac 27-Inch "Core i7" 3.4 (Mid-2011):
      First off I have the Imac Schematic but only for the mainboard, does anyone have the inverter one or a similiar one from another for better understanding?
      Searched all over for one!
      All voltages to the Inverter are correct:
      (12v in, 3.3v Enable and PWM Approx 3.0v).
      Output was 12v and moved a little but Inverter was obviously cutting off as D1 was SHORTED.
      After replacing this the IMAC works for 1 week exactly and dies again. When working the output was correct...
      12-04-2020, 06:58 AM
    • Hounddoghill
      DPS285BP 5v standby transformer blown
      by Hounddoghill
      Sharp TV LC-80LE633U
      Power supply board DPS 285BP Run TKB096WJQZ
      Standby transformer markings (attached picture)
      MP-130I(01)
      AV-DP11153 Delta
      Dcum 1244(03) H6P
      So an event in the primary exploded the cap (C7901)on pin one of the Standby circuit IC. So after replacing a couple diodes a the 2.2ohm resistor(fuse) I found the transformer inputs are open.
      Anyone know about replacements for this transformer?
      I suspect the original is not available.
      https://www.badcaps.net/forum/images/smilies/silly.gif
      02-04-2022, 03:22 PM
    • ohren
      Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
      by ohren
      Hello!
      I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
      Measured voltages with no load:
      After rectifier diodes
      12V: 6.17 V
      5V: 5.67 V
      Secondary transformer pins AC measurement (really don't know if this says anything)
      12V: 2-2.5 V
      5V: 1.04 V
      I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
      03-18-2023, 10:33 AM
    • cmlewis89
      LG 47LB5DF blown power supply board
      by cmlewis89
      Hi folks,
      I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
      09-03-2024, 07:50 PM
