Samsung 731N - Menu persists and cannot be dismissed
  • msmith6477
    • Sep 2012
    My Samsung 731N computer monitor menu screen keeps popping up. Specifically, the menu screen prompt cannot be dismissed. If I toggle any of the monitor control buttons it will go away momentarily but return a few seconds later. Sometimes the menu prompt will move around the screen but usually stays in one area of the screen.
    I have tried updating the firmware with no help.
    I have researched the issue with multiple searches and the only help I found was that the monitor was going bad, duh!
    I have a mechanical background and can fix this if I know what component(s) have failed. I hate having to throw this monitor in the landfill if it can be fixed and it has been a superb monitor until now.
    Thank you for any assistance or commentary on this issue!
  • msmith6477
    • Sep 2012
    Re: Samsung 731N - Menu persists and cannot be dismissed
    update: I goggled my own heading(above) and found a useful link to a tread in this forum. Weird! I tried searching using the search engine of this site but it did not lead me to this thread.
    https://www.badcaps.net/forum/showthread.php?p=141102
    Still, no solution as of yet.
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • Robby-Gr
      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
      by Robby-Gr
      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
      Additional issues:...
      09-27-2025, 12:02 AM
    • Retro140
      Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
      by Retro140
      So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
      To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
      06-18-2023, 06:13 PM
    • Ierwin
      Philips 58PUS7805 Menu working but no/weird picture from video sources
      by Ierwin
      I got a 58pus7805 that shows some weird behavior.
      The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
      However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
      I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
      I managed to install the latest official firmware by holding the control button while plugging...
      03-10-2024, 12:50 PM
    • vf fa
      EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
      by vf fa
      Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
      I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
      So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
      01-31-2024, 01:40 PM
