How to test a voltage regulator
  • retiredcaps
    • Apr 2010
    • 9271
    Regulars will hopefully appreciate this new guide I just wrote so you don't have to explain it over and over again.
    https://www.badcaps.net/forum/showthread.php?p=261329
    PS. Same thread also posted on Troubleshooting TVs and Video Sources as some regulars read one, but not the other.
    --- begin sig file ---
    --- end sig file ---
  • Lumberjack777
    • Dec 2010
    • 464
    Re: How to test a voltage regulator
    Excellent guide retiredcaps!
    Now I can test the voltage regulators, on that main board, on that Dell W3000 I'm working on. Thanks!
      ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
      3+1 Voltage Regulator for IMVP-7/VR12 CPUs
      Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
      core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
      configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
      serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
      Based on Intersil's Robust Ripple Regulator...
      11-05-2024, 03:24 PM
    • playit
      diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
      by playit
      hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
      and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
      for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
      02-26-2025, 05:39 AM
    • chth96
      How Can I test PWM DM0365R?
      by chth96
      Hello
      I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
      So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
      I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
      I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
      06-18-2025, 04:14 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • artvandalai
      Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
      by artvandalai
      This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
      The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
      11-05-2024, 07:38 AM
