HG281D Monitor Problem
  • felstud
    • Aug 2012
    • usa
    Hello all,
    I have a Hanns G 281D that I purchased about three years ago and now i'm currently having a problem with it. The monitor will not work under its normal resolution (1920x1200) without it being fully warmed up. In order for me to "warm up" the monitor I have to use 800x600 resolution and slowly increase the resolution over time. Once I finally get into 1920x1200 over several hours, I have to put a sweat shirt on the back side of the monitor otherwise the picture will go out. The normal blue LED light that shows when the monitor is on stopped a few months after I purchased the monitor so I am unable to tell if it is flashing. I opened up the back of the case to see if any capacitors were bad but I am unable to see any that are faulty. I'll post some pictures on this tomorrow. Does this sound like a capacitor problem to you guys?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: HG281D Monitor Problem
    Not heard anything quite like that. It sounds as though it could be capacitors, but could be a cold joint depending on what you mean by "not work under its normal resolution"- doesnt come on at all, garbled screen, dark screen etc.may be the bulbs or associated wiring.
    Cooking it under a sweatshirt will be doing it no good at all - you will be causing all the caps to deteriorate.
    Look forward to the pics.
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
    • Askic
      Problem with monitor DS-D5022QE-B
      by Askic
      Hello to all,
      I have a problem with monitor that is delivered together with CCTV system.
      The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
      I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
      05-31-2023, 03:14 AM
    • CptChronic
      Samsung LU32J590UQUXEN Monitor display problem
      by CptChronic
      I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
      Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
      But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
      04-24-2023, 04:33 PM
    • tmhobadcap
      LG 24MP56HQ-P Monitor Backlight problem?
      by tmhobadcap
      I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
      Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
      I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
      10-13-2021, 01:52 PM
    • tmhobadcap
      by tmhobadcap
      10-12-2021, 01:43 PM
    • wattage
      by wattage
      Hello Badcaps Community,
      07-13-2025, 04:41 PM
