Samsung SyncMaster 740 N- Wierd Problem
  • KMCHOSP
    • Jul 2012
    • India
    I've a some weird problem with my 4 1/2 year old Samsung SyncMaster 740 N. Its a 17" LCD screen and its acting strange. The screen was flickering a lot along with it half or sometimes even the whole screen is going black. There is no fixed line delineating it from the working regions.
    Now the screen does not work at all while just starting with a glow in the middle against a dark background and slowly growing in size.. I have put a video on youtube if someone is interested. Not sure how to describe this problem..
    http://youtu.be/Ac17KG-16ZY
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung SyncMaster 740 N- Wierd Problem
    1) Post clear focused top down pictures of all your boards following my sig file below exactly. We want the picture compositions like so
    https://www.badcaps.net/forum/showpo...94&postcount=1
    2) Do you have a multimeter and know how to use it? Also post a picture of it.
    --- begin sig file ---
    --- end sig file ---
    • KMCHOSP
      • Jul 2012
      • India
      Thanks for the reply..
      I haven't yet opened the monitor up. And I don't have a multimeter as well.
      I will put up the pictures tomorrow as its too late in the night here but what is the probability of this being a lcd panel/pixel malfunction?
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • mmccomputer
        problem with replacing lcd screen
        by mmccomputer
        I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
        otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
        If anyone has any information on the subject...
        12-15-2024, 03:44 PM
      • Chrissygizmo
        samsung galaxy ao2s very temperamental after screen replaced
        by Chrissygizmo
        Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
        Ive eventually managed to get it on and working but it's very temperamental...
        The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
        05-26-2024, 12:05 AM
      • jimjoe123
        LCD TV Green/Pink screen problem
        by jimjoe123
        I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
        Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
        Then each time...
        02-23-2020, 01:29 AM
      • CityZen
        Samsung un48ju6700 half screen ghosting problem
        by CityZen
        This curved LCD TV has an issue affecting just the right side of the screen. It is not a backlight issue, although it might appear so from one of the attached images. The problem appears to be the right side of the screen not updating properly. Moving images on the very right side will leave a trail of ghost images. Although even just the computer cursor sitting still makes a vertical ghost band the entire height of the image. The color on the right side also looks like it doesn't have the full bit depth (the Windows background looked kind of dithered on that side).
        I went into...
        11-24-2021, 12:03 AM
