"poor Screen" on a Xerox 700P
  • teslacap
    • 27
    Hallo,
    after connecting a Xerox 700P to the computer, I got a very poor screen-picture. That seems similar to 8-bit resolution, but is for sure something else. Is that symptom known by someone? I put 2 pics into the attachment.
    Cheers
  • jetadm123
    • 2169
    Re: "poor Screen" on a Xerox 700P
    Have you tried changing the resolution(s) on the computer's video card?
    • teslacap
      • 27
      Hi jetadm123,
      yes of course I did. That was one of my first thoughts. But the resolution during this two pics were made was 1280x1024 with 32-bit colours. That is definitely not the errors cause.
      Cheers
      • retiredcaps
        • Apr 2010
        • 9271
        1) A long shot would be that one of the voltage regulators on the main board is running out of specification.
        2) You can always try cleaning and reseating all the internal cables.
        --- begin sig file ---
        --- end sig file ---
        • teslacap
          • 27
          Hallo retiredcaps,
          thank you for your "tough-tip". Actually the item 2 was the bug-killer. I repluged everything on the mainboard and also put the MCU out of the socket for to polish the contacts. After back plugging I got full colors! Great!
          Cheers
          • retiredcaps
            • Apr 2010
            • 9271
            Hmm, jetadm123 started around the same time and I think it is safe to say that we have never heard anyone takeout the MCU out of the socket to clean the contacts.
            Glad you got it going.
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
            • spice_disc
              Vizio TV M50-C1 reboot cycle and static on screen
              by spice_disc
              I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
              The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
              09-08-2024, 02:37 PM
            • ipatch
              ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
              by ipatch
              i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
              08-24-2024, 02:36 PM
