Asus MK241H no power
+ More Options
Posts
  • tibimakai
    • Jan 2012
    • 3680
    Re: Asus MK241H no power
    Thank you very much. I will look into it.
    Yesteday I have sent a private message to the person who gave me the resistor values, but I don't have much hope that he will answer.
    Which transistor is the Q101? Which one did you buy?
    • tibimakai
      • Jan 2012
      • 3680
      Never mind, the transistor I have replaced already a while back.
      • HF Specialist
        • 3
        CORRECTION! In the previous post, I said that R172 was .01 ohm. I should have said 0.1 ohms - still 2 watt. BTW the SMT resistors are 805.
        • HF Specialist
          • 3
          Ignore last post - brain fart. Original post was correct. For Q101 I used an STF18NM60N.
          • tibimakai
            • Jan 2012
            • 3680
            I have ordered 0.1 Ohm/2W resistor.
            I'm waiting for the parts to arrive.
            I don't know how come I haven't checked this resistor, it's so obvious that is open, I can actually see a piece blown from it.
            I was concentrating so much on the SMD parts, that I have forgot to actually look on the other side of the board for bad through hole components.
            • tibimakai
              • Jan 2012
              • 3680
              I have replaced the mentioned components and there is no change.
              The only voltage I'm getting is the 166V, nothing else.
              The TEA chip is not getting the right Vcc(which I don't know how much it should be), it's only getting 1.8V. At the pin 8 I have 141V.
              • tibimakai
                • Jan 2012
                • 3680
                I have looked at the TEA pdf and there it is mentioned that the Vcc is getting from the transformer after the PS is started.
                So this IC won't start only after the PS is started.
                I must have another problem that is causing to not start.
                At the output connector that goes to the mainboard, I'm not getting almost anything. On some of the pins I'm getting less then 0.5V.
                Should I have standby voltage? No light turns on, when plugged in.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Nobody can help?
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Nobody can explain to me what should be happening with this PS to be able to start?
                    It should have a standby voltage? On the output connector toward the mainboard, nothing is printed on the board.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I have just gave up and purchased a new board from Ebay ($49.90), put it in and it's working great.
                      The only check I have done is to make sure that we had the right resistors and we did.
                      It's a nice monitor, with webcam, speaker, HDMI input.
                      • stodek
                        • Mar 2013
                        • Poland
                        #71
                        Hi, I have problem with the same asus display. No power, no stby, no led. I found broken D115 Schootky Diode mbrf20200ct. Replace it and now display works!
                        Sorry for my poor english.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I have removed that diode and measured it and it conducts in one way and doesn't conduct the other way. That is good? It shouldn't conduct a bit the other way?
                          • simoesp
                            • Oct 2017
                            • Portugal
                            #73
                            you saved my head from burning
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                            • ShadowAi
                              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                              by ShadowAi
                              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                              03-15-2024, 10:46 AM
                            • meraklinetx
                              Asus Z97-a power cycle, no boot no cpu voltage
                              by meraklinetx
                              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                              05-10-2023, 06:08 AM
                            • conghuyms
                              Request for Help – ASUS G531GW Rev 1.6 – No Power On
                              by conghuyms
                              I need your support with an ASUS G531GW Rev 1.6 laptop.
                              When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
                              Here’s what I’ve checked so far:
                              • Motherboard has been removed for inspection.
                              • 3V and 5V always-on rails are present (3V/5V_ALW).
                              • 1.8V and 1.09V at the PCH are present.
                              • I don’t have the boardview/schematic, so troubleshooting is limited.
                              • I tried checking the power button signal from the
                              07-20-2025, 09:14 PM
