Sony (Dell P1110) Trinitron Monitor with 1 bad cap...
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    I snagged a true flat Sony Trinitron (Dell branded model P1110) 21" monitor for nearly nothing the other day... Of course it didn't work (I knew that when I bought it)... I finally cracked it open today...
    The monitor fired up but had no display... Upon further testing, I discovered that the filament voltage was missing. I substituted filament voltage from an outside power source, and she lit up like a Christmas tree... This told me the CRT wasn't defective, so I started backtracking the filament power circuit. I ended up in the power module, where I discovered a vented Rubycon 100uF 25v cap, (yes KC8, it was a GENUINE Rubycon ). I also discovered a shorted diode package (part# YG802C09) in the path of this fried cap. What probably happened was the diode package shorted, fed back through the cap and popped it. I replaced both components, and viola! The SHARPEST monitor I've ever seen!
    While bad caps was not the initial cause of the trouble, it was the end result...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    thats a common failure.
    when the rectifier fails short/leaky the cap gets ac.
    poof!
    see that on several sony chassis.
    good find!
    • deathamatend
      • Jun 2011
      • 5
      Re: Sony (Dell P1110) Trinitron Monitor with 1 bad cap...
      Topcat, I know this is an old thread, but I also have one of those 21" dell trinitons monitors which I love, too. I have had it apart to clean the dust out a few times, also to tighten a few screws to keep the degaussing noise down, and it is perfectly clean inside and out. One day, on powering it up, I heard a couple of snaps and the picture collapsed to a line down the middle of the picture tube. It is now, not powering up, and the LED power light now blinks yellow when I would plug it in. I am capable of advanced diagnostics and repair. I can add that I followed Badcaps advice and instructions on repairing a Westinghouse SK-19H210S which now works perfectly, so any help provided would be greatly appreciated.
        by momaka
        03-15-2023, 10:17 PM
      • sviru
        Dell P1110 Sony G500 Trinitron fix - not brightness!
        by sviru
        Hi guys I have issues with my "new" P1110.
        The screen is not horizontally centered. From the start. I need to shift the screen and make it bigger to fill the screen. No matter what source xbox/pc/laptop.
        There is also a big distortion you can see here.
        https://ibb.co/NCGKs7N
        Also the screen has a little red shift in the blacks.
        Any ideas? Screen is not too bright.
        08-30-2023, 08:03 AM
      • nick3092
        SGI GDM-5011P CRT Monitor (Sony Trinitron) Help
        by nick3092
        Hello all. I have a 21" Sony Trinitron CRT monitor I'm hoping to repair. It's technically an SGI monitor, model GDM-5011P. I showed the attached pictures to a couple people who are slightly knowledgeable in monitors and/or electronics in general. And the general consensus is that it's an issue with the deflection board, or less likely the power supply. Most likely the deflection board though, as it looks like an issue with the horizontal sync. I'm hoping that it just needs a recap to fix it. The service manual complete with schematics, block diagrams and parts lists is available to view or...
        04-14-2020, 07:05 PM
      • FZG
        Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
        by FZG
        Hello there, helpful forum people!
        I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
        On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
        The original part...
        05-10-2023, 11:54 AM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
