Re: LG L1953S doesn't power on
No, I've got no 5V at all.
What about the 5V output? Does it do the same thing as the 12V output?Leave a comment:
Thank you for your answer..
The voltages I'm talking about are without connecting anything on power supply(just like you see it on pictures )I have soldered a plug and taking measurements but the voltages on connector are missing..
ZD301 is OK, it just has some kind of varnish on itLast edited by Joun; 04-11-2012, 11:43 AM.Leave a comment:
Check zener diode (located on bottom of board) zd301 for shorts. It looks a little discolored.Leave a comment:
The power supply is always on even you do not turn on the monitor, so please check the the DC voltages without turning on the monitor, see if the voltages stay on, if you turn on uinsing the switch and then you see the voltages go down, then the power supply may have gone into shutdown mode due to over current draw due to short circuits.Leave a comment:
Hello
I have this LG monitor that doesn't power on.
Optically everything seems fine and I have check all mosfets,diodes, capacitors but couldn't find anything wrong..
Voltages on connector are absent with one strange expection:The moment I plug the board in I have 12volts but they are descending at a slow rate..
I mean at the begging I have 12volts,ten seconds after I have 11.5, another ten after I have 11, and so on..
I have found service manual but I had no luck with it..I'm starting to think it has a faulty PWM controller but not really sure..Tags: None
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
