VP2030b Flickering
  • Tatu
    • Aug 2011
    VP2030b Flickering
    The VP2030b is a great monitor that I don't want to give up. I also have a newer VG2428wm that just doesn't compare.
    My VP2030b started flickering last year but only when the screen was mostly white. When I changed the display to mostly dark, the flickering stops. Then after extended use, the screen would go black for a few seconds and then return to normal for several minutes. This repeating black out pattern would continue until I turned the monitor off for a while as if to let it cool down. The monitor returns to normal after restarting but eventually goes back to flickering and then the eventual brief black outs.
    I've disassembled the monitor and examined the board, but I'm not sure if capacitors are the problem. None are apparently bulging. Are there other possible explanations or is my next step to submit a few photos?
    Thanks for any help.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: VP2030b Flickering
    1) Caps don't have to bulge in order to be bad.
    2) Yes, post clear focused top down view photos of all your boards following the instructions in my sig file below exactly.
    3) Do you have a multimeter and are you familiar with taking DC voltage measurements?
    --- begin sig file ---
    --- end sig file ---
    • reessi
      ACER BM320 Monitor - Horizonal Flickering Lines After a While
      by reessi
      The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
      They are black on the right and gradually fade to nothing on the far left.
      They start either after 5 mins or up to 2 hours after so annoying for testing.
      They flicker continuously very fast! With a slight pause milli-second every second.
      Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
      I tested each half by removing the first the left flex from...
      06-03-2025, 09:58 AM
      by momaka
      03-15-2023, 10:17 PM
    • wattage
      by wattage
      Hello Badcaps Community,
      07-13-2025, 04:41 PM
    • ant3202
      HP 27es - LED monitor - Monitor Flashing On - Off
      by ant3202
      Hi Everyone
      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
      https://www.badcaps.net/forum/troubl...lashing-on-off
      The monitor is HP 27es LED Monitor
      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
      The monitor will randomly blackout and display no signal and will recover again.
      Sometimes need to power and off again to restore the display but...
      03-20-2025, 07:30 PM
    • Ali101
      AOC LV243XIP 23.8 inch Monitor Screen Flickering
      by Ali101
      AOC LV243XIP 23.8 inch Monitor screen flickering after power on monitor within few seconds and image disappear, if power off and on again then then image come back and again disappear within few seconds, i had checked all capacitor which seems ok to me, i have doubt something wrong with LCD board and mainboard is ok, i don't have other same monitor so i check and verify either LCD have issue or mainboard,
      shall highly appreciated any hep to fix this monitor,
      PS. i had attached pics and short video for reference,
      Video Youtube Link: https://youtu.be/z9hIq7Ujj...
      02-13-2022, 06:21 PM
