Samsung 943b no power on after power off
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    This is from a Samsung 943b which, after power off, will not power on unless switched off at the power point for a while
    Its controls are all touch sensitive, not mechanical
    Nothing obvious wrong to my eyes, nor anything gross when I try my ESR meter on the Sam Young electrolytics in situ
    Suggestions ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung 943b no power on after power off
    Originally posted by pfrcom
    Suggestions ?
    1) Does the power LED come on?
    2) If not, are the secondary voltages and 5V present on the power and logic board?
    3) If present, do the voltage regulators output the correct voltage?
    4) Any cold or bad solder joints?
    --- begin sig file ---
    --- end sig file ---
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      The power LED does come on from a cold start
      But after power off, will not come back on
      Until left for a while switched off at the power point, after which it does come on and monitor works normally
      Not confident about voltage checking, was hoping for an obvious problem
      • retiredcaps
        • Apr 2010
        • 9271
        Post pictures of your boards in this composition
        https://www.badcaps.net/forum/showpo...94&postcount=1
        and I can walk you through measuring the voltages on the secondary side. The voltages on the secondary side are likely to be 24V DC or less. If they are absent, then it will be necessary to measure the primary (HOT) side. If you have aligator clips, it will make measuring the hot side less intimidating as shown by budm in this thread (but we are not measuring for AC - only DC in your situation)
        https://www.badcaps.net/forum/showpo...1&postcount=13
        • selldoor
          Slow Learner
          • 7870
          Service manual is here:
          http://www.scribd.com/doc/56414365/S...Service-Manual
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • mrtek
            Samsung UN43NU6950FXZA No power
            by mrtek
            Hi
            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
            Main fuse = OK
            Back light LED = OK. Power them with aux power source
            LED output = OK 156V
            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
            Yesterday, 08:06 PM
          • hill01
            Samsung UE75MU7009TXZG Endless Power Cycle
            by hill01
            Hi everyone and thanks in advance for any help I might get here
            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
            Since a few days, the TV won't turn...
            11-17-2021, 02:52 PM
