double post... how to delete?
oops...
by chaos-theoryI have a card that does post at all, the owner said it does go into windows but it gets stuck on the logo with artifacts, I have no idea if he is lying or not... I tried the card on my pc and it does not post at, no beeps, no bios nothing just all fans turning and nothing else. I tried plugging DVI or hdmi but nothing, I tried unplugging the 8 pin plug from the power supply and it's the same thing.
I just want it to post and get into the bios at least.
Forgive me if I am wrong, but I tested the 3 PCIe 12v power pins on the left(550ohm) and the 4th one from the right 3.3v (400ohm),... -
by AdminFORUM RULES *ALL NEW MEMBERS, PLEASE READ! UPDATED!*
First and foremost, welcome to the Badcaps Part Search Engine & Electronics Repair Forums!
IMPORTANT NOTICE ON FILE ATTACHMENTS
As with any forum, we are susceptible to our users being targeted with malicious attachments in posts. We do our best to remove anything suspicious but need our users to be cautious. If you are unsure about an attachments legitimacy please ask directly under the post and wait for a reply by an Admin or Moderator. NEVER...-
Channel: Announcements & Related News
by Sorrow1Hi,
I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
When I recorded video of POST card and played it in slow... -
by bbenalmadenaHi, been banging my head two days with a UX461UA Zenbook Asus that will not post. Laptop looks ok, all voltages looks nominal, CPU gets hot, even fan kicks in when it gets hot, I removed the m2 drive and tried several things, I thought it was a bios issue, I even registered here to try flashing with some BIOSes but the problem still was the same, no POST
At last I decided to check the disk drive to see if any backup can be done and then I realized that the disk drive was broken, I thought what are the odds that the motherboard and the drive at the same time? So I just plug another...09-05-2024, 02:18 AM -
Hi there,
Sorry for the double post: I also posted in the Schematics only but couldn't find how to delete the post and I'm apparently not allowed to edit it... My apologies
I'm trying to get the schematics and BV for a Dell XPS 15 9530 (motherboard: LA-L663P)... Can anyone help?
The board powers up for a couple of seconds (the on/off light on the side of the board comes on, no display, no fans rev, no Dell LED code) then shuts down (the on/off light on the side of the board goes off), no liquid damage, no obvious damage to individual components...
... - Loading...
