XPS 15-9530 faulty board LA-L663P
  • eastcoastcomputing
    • Feb 2023
    • 58
    Hi there,
    Sorry for the double post: I also posted in the Schematics only but couldn't find how to delete the post and I'm apparently not allowed to edit it... My apologies
    I'm trying to get the schematics and BV for a Dell XPS 15 9530 (motherboard: LA-L663P)... Can anyone help?
    The board powers up for a couple of seconds (the on/off light on the side of the board comes on, no display, no fans rev, no Dell LED code) then shuts down (the on/off light on the side of the board goes off), no liquid damage, no obvious damage to individual components...
    Any suggestions or advice welcome.
    Thank you
    Update: Actually, I think I have a shorted component. This guy (circled in red) is the only one heating up on the board and gets to temps over 40° within seconds (I have a video on the thermal cam but I can't seem to be allowed to upload it). Can anyone help me identify the chip so I can source a replacement? The cap next to it has a 485 Kilo Ohms resistance.. Is it the culprit?
    Thank you!
  • saiiko
    • May 2025
    • Japan
    Can you post a full board photo?
    Also if you thermal monitor when you connect the battery, this power splitter maybe dumping the 20v to ground as a protection mechanism. Are the CPU / GPU mosfets shorted? What Ω​ do you get from CPU / GPU coils to ground?
    I have the same board, same fault
    • saiiko
      • May 2025
      • Japan
      Check this area specifically - may be a heat issue (4060/4070/4080) middle Atmel mosfet likely overheat.
      Check resistance from 3 GPU coils to ground - do you see 3 OHMS?
        • Feb 2023
        • 58
        Hi Saiko,
        Thank you for your help.
        The GPU coils aren't shorted (nor any other coils for that matter) and I didn't find any issues with the mosfets either. The only component heating up on the thermal cam is the one I circled on the picture. Unfortunately the customers decided against repairing the board and bought a new computer instead so I can't send you a full board picture anymore.
        • Sephir0th
          • Oct 2020
          • 1283
          The picture from #1 looks like a small power supply to me. Don't do the mistake to blindly replace it, it could be that it simply tried to pull current into a short circuit. In this case to replace it would change nothing.
          FairRepair on YouTube
            • Feb 2023
            • 58
            Thank you for the advice. This is one eventuality I was contemplating...
            • saiiko
              • May 2025
              • Japan
              Just for future diagnostics, this is the LDO "linear voltage regulator" which is supposed to be warmer than surrounding chips.
              This means, the 20v USB-C inputs and PD controllers are working (negotiating 20v instead of the default 5v USB) along with the entry MOSFETs carry the power to this chip.
              From here, it creates 3v which provides constant power to the EC chip (other side of board).
              In these situations, where board is taking the usual 20mA standby current (EC Chip being on/waiting for power button keypress) then the following may have happened:
              - Faulty EC firmware (happened due to one of numerous windows forced bios updates)
              - Shorted component (due to overheat, means EC detects over-current and enables protection mode to limit more power, thus saving further damage)
              Replacing the LDO would be like replacing the nozzle on a faulty tap - the problem is always upstream and not due to the surface
              To diagnose:
              - Fully remove board and waterproofing plastic covers
              - When first powering the board - 12v, 5v / 3v and 1v power rails should momentarily appear (1-2s) before protection mode disables them, this would start to pinpoint which rail is down (i.e. 1v CPU/GPU circuits, 12v charging circuit etc).
              - Connect USB-C, and then plug battery: you should see power spikes and if your thermal camera has a fast enough refresh rate, thermal spikes where the short is
              - Perform visual inspection to look cracked caps / burnt or blown
              - A dead short is the same Ω as connecting your leads together i.e 0.3-0.5Ω. Anything more 1-3Ω GPU, 2-5Ω CPU for example
              - Targeted voltage injection (1v max incase of CPU/GPU dual-MOSFET failure (they're the hottest components in intense use)
              - Be mindful if troubleshooting BIOS, these newer machines first load EC which daisychains BIOS later after a successful read. You may think the BIOS isn't receiving 1.8 / 3v to power it, but this is normal.
              TLDR; I think since On light appears, LDO and EC are good, likely a shorted component
              Hope this can help the community, apologies if very basic but may help/encourage new members to ask and help us see and identify common failure modes
                • Feb 2023
                • 58
                Thank you very much, this is very helpful.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • jimbodriver
                  Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
                  by jimbodriver
                  I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
                  Initial results:
                  Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
                  03-20-2022, 02:30 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
